My SL6 came with the previous generation of Red etap (not AXS), including the short cage derailleur. That meant I was limited to 28 teeth cogs. When I wanted to expand the deailleur's capacity, I found the price of the OSPW to be similar, if not less than, the price of SRAM's medium cage derailleur. So yes, I bought mine purely for practical reasons.
Kogel Kolossos vs CeramicSpeed OSPW
it wasn't really was it. you wanted the look of the OSPW, if not you just would have gotten the original SRAM cage. Which is totally fine. Unless you literally don't care or think about how your bike looks.whinefields wrote: ↑Thu May 18, 2023 2:17 pmMy SL6 came with the previous generation of Red etap (not AXS), including the short cage derailleur. That meant I was limited to 28 teeth cogs. When I wanted to expand the deailleur's capacity, I found the price of the OSPW to be similar, if not less than, the price of SRAM's medium cage derailleur. So yes, I bought mine purely for practical reasons.
I was literally up against the same decision as i needed to replace a cage and the coated CP OSPW was the same price as replacing, i decided to get the original cage as i decided against the look of the OSPW.
- wheelsONfire
Nothing at all! just thinking the thread might be drifting towards OSPW yes/no rather than Kogel Vs CS
- wheelsONfire
Aha, no it's probably Kogel if anything! It's the version that catch my interest the most.Bobbyc123 wrote: ↑Thu May 18, 2023 3:09 pmNothing at all! just thinking the thread might be drifting towards OSPW yes/no rather than Kogel Vs CS
I noted Aliexpress already have a copy..
Bikes:
Open *UP* (2016.04.14)
I have the aliexpress copy, running on ultegra r8000. The stock ceramic bearings suck (no seals at all), but I replaced them with decent bearings and have been running it for around 2 years now. No complaints, it was cheap, shifts perfectly and may or may not save any watts. Only issue is any ethical/moral considerations you may have.wheelsONfire wrote: ↑Thu May 18, 2023 3:14 pmAha, no it's probably Kogel if anything! It's the version that catch my interest the most.Bobbyc123 wrote: ↑Thu May 18, 2023 3:09 pmNothing at all! just thinking the thread might be drifting towards OSPW yes/no rather than Kogel Vs CS
2020 Cannondale Supersix
2021 Argon 18 Gallium Disc
2018 Trek Crockett
2018 Trek Crockett
- wheelsONfire
I checked this on sure i could try it. Did you just buy separate bearings and exchanged them?Bfriesen wrote: ↑Sun May 21, 2023 6:42 pmI have the aliexpress copy, running on ultegra r8000. The stock ceramic bearings suck (no seals at all), but I replaced them with decent bearings and have been running it for around 2 years now. No complaints, it was cheap, shifts perfectly and may or may not save any watts. Only issue is any ethical/moral considerations you may have.wheelsONfire wrote: ↑Thu May 18, 2023 3:14 pmAha, no it's probably Kogel if anything! It's the version that catch my interest the most.
(you can pm me if you know the size or have some more to say)
I also checked what new pulley wheels cost for Ceramicspeed.
I can get good price at these, both coated and standard.
Not coated 329 Euro
Coated 399 Euro
That is quite horrible.
Bikes:
I've got a lot of bearings in my purchase history, but I'm 80% sure they are 688-2RS bearings. 8x16x5mm. I bought it out of curiosity with the intention of buying a genuine one if I liked it, but I've had no reason to replace it, it's performed so well.wheelsONfire wrote: ↑Mon May 22, 2023 8:22 amI checked this on sure i could try it. Did you just buy separate bearings and exchanged them?Bfriesen wrote: ↑Sun May 21, 2023 6:42 pmI have the aliexpress copy, running on ultegra r8000. The stock ceramic bearings suck (no seals at all), but I replaced them with decent bearings and have been running it for around 2 years now. No complaints, it was cheap, shifts perfectly and may or may not save any watts. Only issue is any ethical/moral considerations you may have.wheelsONfire wrote: ↑Thu May 18, 2023 3:14 pmAha, no it's probably Kogel if anything! It's the version that catch my interest the most.
Not coated 329 Euro
Coated 399 Euro
Yeah, I just pressed the bearings out with a vise and a block of wood and then pressed the new ones in. Super easy and took me all of 10 minutes. The stock bearings spun forever, but had no lubrication or seals so they would have had a lifespan of approximately 10 minutes.
2018 Trek Crockett
2018 Trek Crockett
Hi. I gambled on one of these and all the bolts were rusted and bearings absolute junk. I'm going to try and save it, got some decent endura bearings but the fake kogel dustcaps were rusted in so had to be destroyed. Any idea what dustcaps I can use for the new bearings?
I have ceramicspeed on three of my bikes and thought i would try the Kogal and its been nothing but problems, it rattles over rough roads and one of the bolts came out and they wanted $150 to ship a new one to Australia or wait months with the distributor. I was actually able to find one in the end because one of the shops said they wont stock them anymore because they originally had this problem with a lot of them so not they locktight them in so much its impossible to get the bolts out to service them and actually had a bunch of dead ones for parts in the shop.
