Yonex Carbonex SLD 540g
ome rodriguez
by ome rodriguez
MrCurrieinahurry wrote:
Fri Apr 14, 2023 4:49 pm
I think what i love about this is only real weight weenie enthusiasts will really appreciate it.
Sorry if ive missed this but whats the build list?!?!
Basso Diamante eps 12
I'm not doing a crazy light build. I still have a brand new dura-ace 9170 groupset from pandemic. Darimo bar/stem/seatpost, berk saddle, and zipp 303 firecrest disc tubular wheels.
ome rodriguez
by ome rodriguez
cajer wrote:
Sat Apr 15, 2023 11:27 pm
Alfonso wrote:
Fri Apr 14, 2023 5:53 am
Good morning.
Good weight.
I thought it would be lighter than specialized aetos, both in frame and fork.
Closely monitor the entire assembly of the bicycle.
Thank you for showing us the weights and components of your bike.
All the best.
It would likley be 50+g lighter if it didn't have the metallic flake paint and instead had a matte black like the aethos.
That's what I thought, should be lighter than my aethos if it was nude carbon.
ome rodriguez
by ome rodriguez
eric01 wrote:
Sun Apr 16, 2023 7:02 am
This looks awesome. How did you manage to get your hands on one? Only sold in japan?
I have a japanese friend. Yes only sold in japan. Thanks
MrCurrieinahurry
by MrCurrieinahurry
ome rodriguez wrote:
Good morning.
Good weight.
All the best.
Not tempted to strip the paint off ImageImage
ome rodriguez
by ome rodriguez
Sorry about the cellphone photos. I was amazed how clean the inside of the frame.
ome rodriguez
by ome rodriguez
Tue Apr 18, 2023 9:59 am
I don't think I can do it.
mike
Resident Pro
by mike
Do not strip off the paint!!!!!
MrCurrieinahurry
by MrCurrieinahurry
ome rodriguez
by ome rodriguez
Yonex booth displayed a bare unfinished frame @ 540g in cycle mode tokyo 2023 last weekend.
So my paint is 69g. 🤔
Maddie
by Maddie
You know now what you have to do
mike
Resident Pro
by mike
That unfinished frame is not pretty at all. The yonex paint distinguishes it from any generic Asian frame out there
Alfonso
by Alfonso
Hello.
I do like to see and have carbon frames seen, whether they are of the same type of carbon or different.
What I don't like about lightweight frames is that the manufacturer usually gives the weight of the smallest frame, unpainted and without the necessary components to be able to use that frame and when you buy it the weight variation is different.
To the 540 gr exposure frame you add the necessary components to be used, any stops and the temples of the front and rear derailleurs and a thin layer of lacquer to leave the carbon visible and you add another 40 grams with little.
Then, within the same size, the weight also tends to vary, they do not usually have the same weight, sometimes they are lighter and others are heavier.
But there are few manufacturers that will tell you the actual weight of the finished frame.
I still like the weight and color of your frame and I wouldn't strip the paint off.
I will continue to see how your bike evolves.
All the best.
MichaelK
by MichaelK
Alfonso wrote:
Fri Apr 21, 2023 6:10 am
That looks so clean and precise inside that I'd wager the variance between frames is very small indeed.
eric01
by eric01
Small batch, made in japan. That means something.
