Spotted the problem.
NEW GP5000S TR
Forum rules
Yes the TL was quite good.
Haven't used S TR as they are too expensive.
More reason not to bother then.
Used Pirelli P Zero race TLR and Michellin Power Road without issue puncture wise.
Got Corsa N.EXT TLR to go on next.
I prefer the GP5K S TR. Far easier to install. Better sidewall protection against flinty stones, wood chips, etc.
Cheers. I've never done a Conti sidewall but have heard others strike the problem.TobinHatesYou wrote: ↑Mon Nov 21, 2022 3:54 amI prefer the GP5K S TR. Far easier to install. Better sidewall protection against flinty stones, wood chips, etc.
Thousands and thousands of ks on GP4KS, that were supposedly sidewall weak.
I do love their tyres but so do others unfortunately, hence the price at the moment
changing to mucoff...had the tire checked...sidewall pin size hole...=(
paulpongco wrote: ↑Tue Nov 22, 2022 4:06 am
Muc-Off is a good "demo" sealant as it will get where it needs to go with a healthy initial pour. However instead of becoming a lower volume of still liquid sealant, it slowly becomes a more viscous mass. Unless you frequently top off with more sealant, it will become much less effective at sealing punctures.
Also it's on the heavy side when dry. Dried Muc-Off weighs twice as much as dried Orange Seal.
Should i change sealant more frequently (every 2 months) then with MucOff? Orange Seal is not available in my country (Philippines)TobinHatesYou wrote: ↑Tue Nov 22, 2022 4:12 ampaulpongco wrote: ↑Tue Nov 22, 2022 4:06 am
Just mounted up a set of 32mm S TRs, my first foray into road tubeless. I don’t get a lot of punctures as it is, but if they can save me from having to change a tube over the winter, then it’ll be worth it.
Does anybody happen to know if the Contis 5000 S TR are compatible with hookless rims such as the Enve SES 4.5 ? Thank you !
2023 Cervelo S5, size 56, sapphire/ice
George46GR wrote: ↑Sat Jan 07, 2023 5:49 pmDoes anybody happen to know if the Contis 5000 S TR are compatible with hookless rims such as the Enve SES 4.5 ? Thank you !
Yes.
Conti is one of the few manufacturers who have printed a specific pressure for Hooked and HL on the tires. Well done!
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Thank you for your answers. Still, I feel a bit unsafe to instal a (tubeless) tyre on a hookless rim. Or is it just due to the fact that I am familiar with hooked rims only?
I was looking the ENVE SES 4.5 wheels for my 2023 Cervelo S5. Excellent wheels, but hookles......
George46GR wrote: ↑Sun Jan 08, 2023 3:20 pmThank you for your answers. Still, I feel a bit unsafe to instal a (tubeless) tyre on a hookless rim. Or is it just due to the fact that I am familiar with hooked rims only?
There are plenty of hooked options around 50mm depth.
If you are fine with the HL compatible tires (like the S TR), the choice is just about the other stuff. For me, HL doesn't offer any real disadvantage at this stage. Was very different a couple years back, where hardly any tires were offered.
