And the strength of ten Mr Olympia champions!
DT Swiss 240 EXP - Engagement Problems
Forum rules
If you look at the pic. you can see the fixed rachet being stopped by a machined lip. So that way the threads don't get damaged by excessive drive torque. While it's likely to be very tight, I don't think it'll be too hard to remove with the right tools. I think this is the tool needed to removed the fixed rachet from the hub. Quite pricy at $76 USD. Or you can buy a whole EXP tool set for $140 USD.
The threaded ratchet is acutally very easy to remove. In fact, you don't even need a wrench to do so...just place the tool in a vice, and give the wheel a twist.
The only hard part it shelling out the $$$ for the tool...
Maybe I am misunderstanding your question, but this has been a requirement for replacing the inner drive-side bearing in DT Swiss rear hubs with star ratchets for more than 20-years! On a more positive note, it is very rare for bearings needing to be replaced in a DT Swiss hub.
- Michael
I've been riding LB wheels with the 240 exp hub since August 2020, probably 4-5,000 km - so far I have had 0 issues (maybe I lucked out). I do notice when descending the free hub sound starts louds and then almost disappears, but re-engages straight away when pedalling.
Have about 350 miles on them so far, no engagement issues.
Had an odd sound coming from the freehub yesterday, after rinsing some debris out of the cassette/rd/chain, prob got some water inside there. I cleaned everything out and regreased with DT red grease. Sound went away, and I’ve noticed the sound when coasting is a bit louder, and more consistent, doesn’t fade out anymore. Sounds more like my other DT hubs now.
Not sure if that really means anything, but I’ll continue to keep an eye on it, and hopefully they’ll keep working properly.
Bummer. My two recently purchased wheelsets both have '0's. At this point it's unclear to me whether DT Swiss will replace the internals on all hubs with '0's or just those that show signs of wear. It would be nice if DT Swiss can issue further guidance on how to check if one's '0' hub has the correct or bad type of surface finish. This info. was probably given to DT Swiss service centers. But how many of those service centers are out there? Are they the same as bike shops that are certified to sell DT Swiss products? I'd hate to lose the use of my wheels just for a simple inspection.
My bet is that DT Swiss just recently came to the conclusion on this. So there could be very few hubs with '1's out there, or perhaps even none! If anyone has a '1' please report it here.
I have just send a question to DT Swiss asking if my hub could be affected (the serial number has the '0' in it) and they answerred quickly that they will rebuild the hub. They have send my request through to the local (The Netherlands) service center, so I am now awaiting their instructions which probably will come after the weekend.
I've been in touch with them over the past week and they told me they've been gathering information over the past few weeks with all the exp issues that were reported to them, I guess they wanted to wait until they had a fix before they said anything. They was aware of this and the mtbr thread.
I'm just glad they know what the issue is and this should be the end of it, I was worried this was going to drag on and on with the hub not being fixed and having to be returned to them again.
Mines at the uk service centre, they should have the parts in the next few days to change in the hub so hopefully I'll have the wheel back soon
Just saw a commet under the MTBR thread that is interesting. I have 305 miles on one wheel and 205 miles on another wheel, so far with no issues. I'm hoping that once I passed the 500mi. mark chances are mine are OK. Keeping my fingers crossed.
Quoted from DT Swiss via MTBR
What we have seen in most cases with EXP hubs not engaging is the problem presents itself within 100 miles of riding, if you have several hundred miles on the hubs then I would say that you are in good shape! but I would still strongly suggest that you inspect the internals of the hub very closely and see if there is damage to the teeth of that ratchets or scaring inside the free hub body. If you notice any damage then these parts will need to be replaced.
