I was always taught to avoid it...No?spdntrxi wrote: ↑Sun Jan 01, 2023 2:33 amI love big bigCampyforever wrote: ↑Sun Jan 01, 2023 2:14 amIt still would be nice to able to lock-out the big/big combo?
Dura-Ace R9200
yeah I avoid it for the most part and wont stay for extended periods, but I try to setup my bike where it's usable... I'd much rather stay in the big ring if possible.Campyforever wrote: ↑Sun Jan 01, 2023 3:18 amI was always taught to avoid it...No?spdntrxi wrote: ↑Sun Jan 01, 2023 2:33 amI love big bigCampyforever wrote: ↑Sun Jan 01, 2023 2:14 amIt still would be nice to able to lock-out the big/big combo?
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
For this reason, I'm starting to love my 1x setup more and more. In late 2021 I moved to and now ride in an area that's either up or down (with gradients above 5%) in every direction but nothing sustained for more than 40-60sec. There's barely a flat road around. In these situations a 2x is frankly an annoyance and results in waaaay too much front shifting (and compo shifts in the rear).TobinHatesYou wrote: ↑Sat Dec 31, 2022 11:08 pmCampyforever wrote: ↑Sat Dec 31, 2022 10:00 pmyes, that was a typo
thanks! So this is by design?
I wish I could get it to happen on the other side as well
Meaning: no big+big....
Am i the only one who did not realize this was by design?
God, I could have torn my hair out....
Shifting into big-big is preferred to dropping into the small ring for very short, punchy ramps IMO, especially in a race scenario. When you shift up front you are making two big jumps and losing momentum in both shift directions... even if you are performing a very quick compensation "synchro shift."
On the other hand it pretty much never makes sense to be in small-small combos.
Small-small can cause the chain to rub the big ring. That's why the lock-out exists.Campyforever wrote: ↑Sun Jan 01, 2023 2:14 amIt still would be nice to able to lock-out the big/big combo?
The Shimano combos are 50-34, 52-36 & 54-40.Campyforever wrote: ↑Sun Jan 01, 2023 3:16 amHere is another DA 12 question:
There are only 3 "approved" chainring combos- 34/50, 35/52 and 42/54
oK- so how about an answer?BdaGhisallo wrote: ↑Sun Jan 01, 2023 11:00 amThe Shimano combos are 50-34, 52-36 & 54-40.Campyforever wrote: ↑Sun Jan 01, 2023 3:16 amHere is another DA 12 question:
that is the answer. That is the chainring sizes they make and for example what others make as well.. ie Carbon-Ti Evo rings. Does not mean others will not work. On my 11 speed bike I run 52/34 and so does my neighbor after he noticed I was having no issues.Campyforever wrote: ↑Sun Jan 01, 2023 2:34 pmoK- so how about an answer?BdaGhisallo wrote: ↑Sun Jan 01, 2023 11:00 amThe Shimano combos are 50-34, 52-36 & 54-40.Campyforever wrote: ↑Sun Jan 01, 2023 3:16 amHere is another DA 12 question:
2023 Pivot E-Vault
2023 Pivot E-Vault
Huh? My question had to do with mixing and matching chainrings....
- Moderator
To be fair to others it was worded poorly and did not read like thatCampyforever wrote: ↑Sun Jan 01, 2023 3:04 pmHuh? My question had to do with mixing and matching chainrings....
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
If this is unclear, god help us...CustomMetal wrote: ↑Sun Jan 01, 2023 3:48 pmTo be fair to others it was worded poorly and did not read like thatCampyforever wrote: ↑Sun Jan 01, 2023 3:04 pmHuh? My question had to do with mixing and matching chainrings....
What would happen if an aftermarket 40 is combined with a 50 or if a 40 is added to the 52?
I can speculate that shifting will not be any good.... but has anyone experimented with alternative
chainrings? Are there any rules to follow?
- wheelsONfire
With respect to the idea of using big ring (or one) i mostly use my 50T and seldom small, that's why i use 50/36.
I'd rather use 50/37 as Sram AXS, but without the 10t cassette cog. I feel the 11t cog feels restrained already.
I wonder what next groupset update will be talking Sram. I hope it's more than the shifters design.
Will Sram ever progress away from JAW and use a motor instead (more Shimano styled).
Or will they use that patent of a chainset with the FD integrated!?
Bikes:
Open *UP* (2016.04.14)
I have Miche 48-33 chainrings... and I have also used 48-35 on Sram Red GXP cranks, and the Ultegra 8150 derailleur is fine... better than the Dura-ace 9070 that I used before with 11sCampyforever wrote: ↑Sun Jan 01, 2023 3:50 pmIf this is unclear, god help us...CustomMetal wrote: ↑Sun Jan 01, 2023 3:48 pmTo be fair to others it was worded poorly and did not read like thatCampyforever wrote: ↑Sun Jan 01, 2023 3:04 pmHuh? My question had to do with mixing and matching chainrings....
the original question was unclear, not your follow up asking about mixed chainrings... anyways you have to try and see.Campyforever wrote: ↑Sun Jan 01, 2023 3:50 pmIf this is unclear, god help us...CustomMetal wrote: ↑Sun Jan 01, 2023 3:48 pmTo be fair to others it was worded poorly and did not read like thatCampyforever wrote: ↑Sun Jan 01, 2023 3:04 pmHuh? My question had to do with mixing and matching chainrings....
I like to get Carbon-Ti Evo, but would prefer to run the 52/34 combo that I do now. My 11sp bike runs an extralite 52/34 with no issues. Per extralite this is not a approved combo.
2023 Pivot E-Vault
2023 Pivot E-Vault
Can the SM-PCE01 be used to update the firmware on 12sp DI2 components with the new Y79M9801T SD300 connector cable?
Or is the SM-PCE02 the only option these days?
