Wheels for the Canyon Aeroad Disc
Bordcla
by Bordcla
Rode my Canyon Aeroad Disc for the 1st time this week. The bike is sensational! Climbed close to 7000 meters on it and it even does that as well as any bike I've ridden.
I rode the stock 62mm Reynolds up and down Mount Lemmon and had a bit of a concern in strong crosswinds coming down. Let's just say it was borderline skittish at times.
I had already committed to purchasing a lighter wheelset for the Haute Route Alps, and had chosen the Roval CLX 50 Disc, which are a good 300g lighter than my Reynolds.
However, given the experience of descending for 20 miles in strong crosswinds with the stock wheelset, I'm questioning whether 50mm, even with more of a modern "blunt" profile like the Rovals, is a good choice for Haute Route (which will see me descend 20,000 + meters) or whether something shallower might be better?
Would Enve 3.4 Disc wheels be any better in crosswinds and worth going with their shallower profile and steeper price, considering they are the same weight as the deeper Rovals? Or would the stability difference be only marginal?
jlok
by jlok
get CLX32 UP front and CLX50 at the rear.
Sent from my SM-N9500 using Tapatalk
jasjas
by jasjas
Why not Mavics COSMIC PRO CARBON SL UST DISC ? i ve used the rim brake version and the older 52 mm Exalith ones with no issues in the Pyrenees.
64mm on a bike like the Aeroad is silly and its why i didnt buy one.
check6
by check6
While not disc wheels and not scientifically based input, I run a set of Enve 3.4s, Zipp 303s and Zipp 404s. There is a big change in cross-wind handling as you go from the 3.4s to the 303s and the 404s can be downright exciting at times. I would think the 3.4s would serve you well both in terms of handling wind and still remain light and somewhat aero.
Stickman
by Stickman
jlok wrote:
Mon Apr 09, 2018 11:01 am
Agreed, go "the mullet" - it's what Giant has done for their 2018 Propel bikes. Shallower on the front wheel for crosswind stability, deeper on the back for optimal aero
Bordcla
by Bordcla
32 mm on the front isn't just "shallower"; isn't it basically un-aero?
jlok
by jlok
yes it's always a trade off between aero and cross-wind resistance... if more aero is needed clx50 it is then...
dcorn
by dcorn
According to specialized, the new wide CLX32 is more aero than their old 40mm carbon wheels.
Are you that fast going up a hill that you're worried about aero wheels? If I bought a set of wheels for climbing, they'd be very shallow (and light) like the CLX32 or 202s.
Stickman
by Stickman
Bordcla wrote:
Wed Apr 11, 2018 4:56 pm
Admittdely the Propel 2018 uses 48mm front and 65mm rear
karmaz
by karmaz
jasjas wrote:
Mon Apr 09, 2018 11:11 am
Cosmics are quite sensitive to crosswinds. At least for me, being a lighter rider, there's a noticable difference compared to my 303's.
Rider27
by Rider27
Hey.
Do you find a solution for your Aeroad dsic concerning wheels?
I'm on the same logic and close to buy some clx50 to replace the dtswiss arc1400.
I'd like your opinion whatever choice you make.
Noctiluxx
by Noctiluxx
Enve 5.6 disk. By far the best deep wheels I've ridden in cross winds.
Bianchi Oltre XR4, De Rosa SK Pininfarina, Trek Madone SLR, Giant TCR Advanced SL, Cervelo R5 Disk, Giant Revolt
RedbullFiXX
by RedbullFiXX
Maybe just pick up an AR41 for the front when you need it ?
Cyclocross, in general, is about riding the wrong bike for the conditions.
CR987
by CR987
I had the Hunt 50mm wide aero wheels and they are EXTREMELY twitchy in even the slightest of winds. My previous pair of no brand Chinese wheels outperformed them in the wind, weight and braking
justonwo
by justonwo
My Zipp 303 NSW wheels are pretty sketchy is strong cross wind. My Enve 3.4 SES somewhat less so. If cross wind is the main consideration, I would do as others suggest and get a shallower front wheel.
It's not very aero to get blown off the road in a cross wind.
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
