Lightest expander for Columbus Minimal 1" Fork
nex
by nex
I currently have the standard expander that came with the fork.
I was looking at the Extralite Ultrastar, but I'm not sure if it would fit. Another option I'm considering is the Schmolke carbon ahead plugs.
Anyone with a similar setup have any words of advice to share?
EDIT: measured the internal width of the fork, looks like it's around 2.0-2.1 cm. So no Extralite Ultrastar.
shimmeD
by shimmeD
Ow, that's so close. Could you file down the alloy parts and make the Ultrastar smaller dia?
Less is more.
silvalis
by silvalis
Not sure if this will work? Sold as a expander for the Hylix 1" fork.
https://www.ebay.com/itm/-/351858116969?
Chasse patate
UpFromOne
by UpFromOne
JRC can fit 21mm ID:
https://www.ebay.com/itm/JRC-Superlight ... SwjL5ZE5mH
But that J&L one looks even lighter - good find!
Squashednuts
by Squashednuts
+1 for JRC
https://www.jrc-components.com/collecti ... t-expander
Great product IMO.
You can buy direct from JRC...good company to deal with
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
nex
by nex
silvalis wrote:
Tue Feb 27, 2018 5:11 am
That looks pretty good, thanks.
jrccomponents
by jrccomponents
Thanks for the mention guys. Just to confirm the expander does in fact fit 1" forks without hassle. Heres a terrible example pic for reference :) Without any expansion the plug is quite small so any 1" fork should be fine unless the iD is tiny
