Chain line problem
- miltmaster3
Frame : s works sl5. bottom :bb30 . crank : rotor 3d+ 30mm. group set : dura ace 9000. spider : power2max .chainset: rotor non q 130bcd 53-39 . problem: when I have 39 -11 the chain touch the 53 chainring make the chain jump! the front derailleur is correct is it normal? The chain line is 43.5
in watt mode
in watt mode
πατα τραβα ρε
That's normal with non-standard setups. Solution: Never use small/small. Unlike big/big there is no reason to use it.
- bikerjulio
It's not a chain line problem. It's operator error. http://forums.roadbikereview.com/components-wrenching/chain-rubbing-big-chain-ring-358017.html
There's sometimes a buggy.
One.
One.
- miltmaster3
Thanks you all
in watt mode
in watt mode
πατα τραβα ρε
Just for the record:
Yeah, we all know you shouldn't use the extreme cross chain positions. But I have been doing it all the time for decades with no apparent negative effects.
In the small-small combo, you run the risk of having the chain rub against the big chainring. I have had that occasionally, but solved it by adjusting the derailleur hanger. The derailleur should be "straight" using an alignment tool, but all specifications have a tolerance, and I just set mine so that it is "in" slightly and "pointed" toward the little chainring (pointing in toward the front).
I am staying "within tolerances" so my hanger is still "aligned properly". I can't remember the spec, but I think it is like +/- 2mm when the derailleur adjustment rod is measuring to the wheel's rim ?
Chainstay length will also affect this, with shorter chainstays causing more problems; and chainring design will also create differences. I was unable to get WickWerx chainrings to operate at all in the X-chain position because they are a bit thicker and have thicker molded-in ramps. (Even though they were otherwise very nice and quick-shifting rings!)
Of course everything has to be adjusted CAREFULLY in every scenario.
Maybe Rotor chainrings are thicker as well.
- miltmaster3
My derailleur has nothing to do I have lot of space between derailleur and chain
in watt mode
in watt mode
πατα τραβα ρε
- Location: United Kingdom of Great Britain and Northern Ireland
How well is your crankset centred?
If chainsatys are symmetric, measure gap between tip of each crank arm and chainstay. Use spacers to adjust position of axle/chainline. That is what spacers are for.
- miltmaster3
Chain line is OK 43.5. I put 3 spacers but nothing
in watt mode
in watt mode
πατα τραβα ρε
It's normal with standard set ups.Marin wrote:That's normal with non-standard setups.
I've had it on 7, 8, 9, 10 and now 11.
It seemed to be slightly be better on campag and the new shimano 11 seems better than the outgoing 10.
Either don't use those ratios. Get a different cassette to change the angle the chain comes in at. (Bigger is better) or a smaller step between chainrings (42/53)
Don't muck around twisting hangers.
FWIW most bikes used to have chainstay length that was very close or under to shimanos minimum requirement. Which makes the problem worse.
Don't know what the current standard is though.
- jekyll man
Change your back wheel to one where the cassette sits a little more inboard?
Official cafe stop tester
- miltmaster3
Rotor knows the problem there is noting I Can do I will always lose 1 or 2 speed in 39 disk. The have the problem with s works sl4 (not with rubeux) I have 2 option 1 keep it 2 get s works crank arm's
in watt mode
in watt mode
πατα τραβα ρε
Sworks cranks are unlikely to fix the issue either.
You either have to have the rings far enough apart that the chain doesn't rub, at which point they won't shift either. Or push the chain line so far out that you can't use half the cassette on the big ring.
You don't have the issue on the Roubaix as I suspect the chainstays are longer.
- miltmaster3
That was rotor answer when I email them about my problem
in watt mode
in watt mode
πατα τραβα ρε
