Weight reduction plan for ROSE X-LITE TEAM
Xico
by Xico
Hi all!
I currently own a ROSE X-LITE TEAM with the following components:
-Frame: ROSE X-LITE TEAM (50cm)
-Fork: ROSE
-Headset: FSA (no idea of the model)
-Spacers: Extralite (1x10mm + 2x5mm)
-Stem: Extralite HyperStem (6° 90mm)
-Expander: Extralite UltraStar 3
-Stem Top Cap: Extralite Hypercap (with hollow bolt)
-Bars: Superlogic Evocurve (40cm)
-Bar Tape: fi´zi:k Microtex
-Shifters: SRAM RED22
-Front Derailleur: SRAM RED22
-Rear Derailleur: SRAM RED22
-Cassette: SRAM RED22
-Housing and Cable for drivetrain: SRAM
-Crank: SRAM RED22 Compact 50/34
-Chainrings: SRAM Compact 50/34
-Pedals: Speedplay Zero Titanium (59mm spindle length)
-Bottom Bracket Bearings: SRAM RED
-Chain: SRAM PC1190
-Brake Calipers: SRAM RED (with Ti center nut)
-Housing and Cable for brakes: SRAM
-Saddle: SMUD-Carbon (light) or SQlab 611 Active Race (training for a 540Km race)
-Seatpost: SMUD-Carbon 27.2mm x 350mm
-Clamp: Not possible to change. Ti Bolt
-Wheels: Mavic R-SYS SLR
-Tires: Mavic Yksion Pro PowerLink and GripLink
-Tubes: Continental Race 28 Supersonic Tube (42mm Valve)
-Skewers: Extralite Streeters
-Bottle Cages: Carbon Works with aluminium bolts.
2 pictures before some of the upgrades:
Where do you all recommend to start shaving some grams? :D
duvivr6
by duvivr6
What does it weight now?
njyeti
by njyeti
If you like the feel of the WCS Evocurve- switch to the Superlogic version - http://ritcheylogic.com/road/bars/super ... d-bar.html
195 grams. Outside of Ritchey, there are lighter bars out there like MCFK- but these Superlogic have the same shape that you are on.
Xico
by Xico
At the moment I don't have the actual weight. I did some upgrades after the last weighting and my weight scale is now broken. But I believe that it should be around 5.750g with the SMUD saddle...
Need to buy a new scale...
danbjpa
by danbjpa
Its already light. Maybe I-link and mini i-link housing are cheap upgrade. Others deserve much money:
Crankset - clavicula, lightning, ax morpheus...
Rings - praxis, bor, stronglight, fibre-lyte
Handlebar - schmolke, haero carbon, mcfk...
Brakes - ee, thm fibula, ax orion/3000...
Wheels...
Edit: or tuned parts... Shave, drill... [emoji3]
Xico
by Xico
njyeti wrote:If you like the feel of the WCS Evocurve- switch to the Superlogic version - http://ritcheylogic.com/road/bars/super ... d-bar.html
Thanks njyeti. I already have the Superlogic version. I will edit the components list.
One "less expensive" part to upgrade for now... :(
danbjpa wrote:Its already light. Maybe I-link and mini i-link housing are cheap upgrade. Others deserve much money:
Wheels...
Thanks for the suggestions. I will start with the cheaper parts... Rings and Cable Housings.
- What are the best chainrings where I can get some weight improvement, but without sacrificing performance?
- Regarding the Cable Housings, I've been considering the I-Link and Mini I-Link for some time, but cannot find much information of which ones are better (Nokon, Alligator, Jagwire, etc...). Can someone enlighten me on this?
RyanH
by RyanH
Sram red rings are 178g. I think you can find New Old Stock force rings which weigh 120g. Praxis I think are closer to 140g. I did not like the shifting on Strong light rings.
Alligator I links have been around for a long time. The only drawback I think is that they occasionally creak, but wiping them down and adding a little lube fixes it. They work very well though.
Oh, and you can save weight by only running a single computer, that's free.
Sent from my VS986 using Tapatalk
Xico
by Xico
Always learning!
Will investigate the older force rings. Seems like a good option!
2 Computers (Edge 810 + Forerunner 920XT) »» I am/was new in town/country, and to not get lost, I was using the Edge 810 for map (always on), and the 920XT for speed/cadence/HR. Maybe a bit overkill! :mrgreen:
Xico
by Xico
Which wheels do you recommend for this bike, for a 540km "competition" (Styrkepröven in Norway)?
Currently on clinchers (Mavic R-SYS SLR), but considering a change to tubulars (I have zero experience with tubulars).
Devon
by Devon
Xico wrote:2 Computers (Edge 810 + Forerunner 920XT) »» I am/was new in town/country, and to not get lost, I was using the Edge 810 for map (always on), and the 920XT for speed/cadence/HR. Maybe a bit overkill! :mrgreen:
But isn't getting lost the fun part? And the best way to learn your way around... 8)
Marin
by Marin
Exgtralite / Stronglight / tune / BOR rings will save some weigh.
Apart from that, wheels. Superlight carbon clinchers for weight, tubular for really low weight, or aero wheels for speed...
For Styrkepröven definitely 35-55m 23-25mm wide U-shape to be stable in crosswinds when you're tired. Should be possible to build a set @ 1350g.
And FFS get some decent tires man!
chris14
by chris14
How about:
Recon K7 , BTP shifter clamps and fibre-lyte jockey wheels with fsa polycarbonate headset spacers (very light and cheap)
Wookski
by Wookski
Praxis rings will drop some weight and improve shifting. If you want to go full WW on the housing try aican bungarus. Wheels- enve 2.2 tubulars laced to extralites will get you sub kilo easy. Brakes- ee as others have mentioned, don't bother with any of the other WW braking options if you actually want to stop. Tyres- plenty to be saved there; Rubino pro speed 23's for clinchers or veloflex extreme tubs. Try YBN ti chain to kill another 30g, tune your pedals (butterflies). Cranks- THM. Bars could drop 40g through some of the options listed above. Carbon rear mech pulleys etc etc... Get out the Dremel?
Wookski
by Wookski
Oh and try werking cycles for a carbon Garmin mount
Wookski
by Wookski
pak0815 wrote:how about lightweight component brands.. ax lightness, mcfk, tune... etc.
Smud and Extralite not WW enough? :noidea:
