Colnago C40 - Project Build - help needed
Nearly finished my build. Just the bottle cages to put on ..... Don't suppose anyone could tell me the bolt size!!!
Thanks Dogg; eventually found the ones I took off but they need replacing as the threads are a bit dodgy.
Very beautiful frame!!!
Will you remove "Oval" logo from the stem?
Will post some photos later. Ended up using some 3t bars and stem I had sitting around as the drop on -17 stem was severe. Reach was a bit short too as I couldn't find a 110mm. 3t's will be de-logo'd in time or replace with something stealth.....
Final build (for now!). Really pleased - didn't intend to build a WW but came in at 6.9kg.
Wheels will be swapped for stans a340 once rear repaired.
Just need to ride it now .... I am a campag virgin so should be interesting!!!
Damn - just realised wrong rear sprocket for photos. I shall flog myself later.
