Ridley Noah FAST (updated pics on Page 4)
ultyguy
by ultyguy
Absolutely lovely....and mean :twisted:
Tamu8104
by Tamu8104
tenax wrote:What size is the frameset? BEAUTY!
It's a medium frame (which is about a 56)
Firefly Ti Road Disc
Firefly Ti Gravel Disc
Rock Lobster Team Tig SL Disc
Santa Cruz Blur 2019
Gaulzetti Cabron Disc (Retired to the Kickr after an accident)
LouisN
by LouisN
How did you setup the rear ( integrated )brake housing ? I'd like to see a pic if possible...
:beerchug: BTW..
Louis :)
Bely
by Bely
This bike is so awesome.. Never really liked the the Noah but this screams WIN!!! Congrats on a veauty
Current
Festka Scala | Pego Respo | English V3 | Colnago EPS Erik Zabel | Colnago V4rs
Incoming
Monkeyboy3333
by Monkeyboy3333
looks FAF!
sjc166
by sjc166
Great looking bike. So much so that it could be a contender for my next ride. Love it
Mario Jr.
by Mario Jr.
No problems riding these wide rims in the Fast forks? Ridley claims that 23mm is the widest rims to be used.
astranoc
by astranoc
This is really nice. I am not too thrilled though on the battery under the saddle.
Tamu8104
by Tamu8104
So it's now 7.20 kg including pedals, cages, garmin mount, etc. Managed to loose about 200g switching the shifters and derailleurs from 6070 to 9070. Still running it as 10 spd for now, concerned about the rotor rings working with the 11 spd. If I put my Reynolds KOMs on it, it's down to 6.76 kg.
@Mario Jr.
No issues with the rims. The ENVEs are 26 front and 23 rear respectively. I think the HED C2 28 would be to tight though.
KWalker
by KWalker
I've ran Rotor rings with 10/11 with almost no problems. Depending on your chainline, you could get some chain drop in big/big, but I solved this by biasing my cage inwards slightly and using the cage rotation screw (9000) to get it perfect.
Gramz
Failed Custom Bike
Tamu8104
by Tamu8104
Yea, the issue I have is with the 11 spd chain. Still trying to get the front shifting right. Trying to find the balance to where it won't overshift when going to the big ring up front and also keep the outer side from rubbing when it auto trims while I move towards big/big. The crazy thing is I don't have the problem with the 10 spd chain. It won't overshift up front when it's set up not to rub through the whole range.
ultyguy
by ultyguy
How was the clearance w/ the Enve (both 6/7 and 8/9), I've heard clearances are quite small on Noah's? Not sure about the Fast...
Tamu8104
by Tamu8104
The frame has no issues with the rim clearance on the ENVE wheels. I've never had any rub and have been using them for over a year. I don't know that I would go much wider than the ENVE's. I think if you put the HED with the 28mm width rims, it would be so close that any deflection in the wheel might cause rub. I've also run 25c tires on it without any problems but couldn't go any bigger then that (not sure why anyone would on this frame).
The only limiting factor of the FAST is the brakes are meant for traditional width rims. Since they are frame integrated, you can't upgrade to wider rim friendly brakes. I solved this by shaving some ENVE pads to provide the necessary clearance. No problems with this set up over the last year.
ultyguy
by ultyguy
Cool, thanks a ton for the input. Mine is not a 'fast' one but the 2013 one, but I think it'll turn out similar. I think the Enve's are like 24mm wide at the back, Firecrests 26mm, and Stingers 28mm...
http://www.slowtwitch.com/Tech/Rim_Widt ... _3537.html
Bregnhoj
by Bregnhoj
Your Ridley is pure bikeporn. I'm in love with it!
The only thing i could put a finger on, is that you need a SRM instead of the Quarq. It would truly do this mega pro-looking bike justice!
My bikes incl. De Rosa Superking and Cervelo R3
Twitter & Instagram - @mathiasbregnhoj
