THM Clavicula SE 172.5 crankset in matte finish - 298g including all hardware/spacer. Very good condition overall visually, with just some minor scuffs to the clearcoat on the arms. Spindle is immaculate.
The cap was partially unscrewed once without removing the grub screws which caused some shallow gouging to the end of the splines on the spindle, and the cap. It doesn't affect assembly, and I've tidied this up (see pics below). It's functionally 100%, and visually almost imperceptible once assembled. Used since without any issues. If you wanted to replace the cap, these can be bought from THM/dulight etc, but I didn't feel the need to.
Amazing super light crank - the obvious choice for a true WW build.
£700 to me after fees/delivery
THM Clavicula SE. 172.5mm, 298g £700
