46-36 FC-R8100/FC-R9200 update
ooo
by ooo
FC-R8100 FC-R9200 FD-R8150 FD-R9250
now officially support 46-36 combo
FC-R7100 FD-R7150 FD-R7100
no support this combo right now
robertbb
by robertbb
Wait, whaaaaaat?
There's nothing I can see on Shimano website?
Edit: OK, can see it there now. Have the Ultegra/DA front derailleurs been pre-designed to be mounted lower on a standard road-bike braze-on to accomodate the 46t ring? I get a sense this might not work on some bikes with braze-ons too high?
robertbb
by robertbb
Shimano Australia didn't even know this was out yet when I rang to enquire about availability...
Having considered this further, I can't understand why Shimano introduced this on race-focused Ultegra/DA and not on 105...?
105 (particularly as the derailleur has compatability with the 11-36) is being marketed as the "all-road" middle ground between DA/Ultegra (pure race setup) and GRX 12 (with it's gravel focused +2.5mm chainline and clutched RD). Perfect for for weekend warriors doing sportives and such, with the standard road chainline and these are precisely the kinds of riders who would benefit from these chainrings.
ooo
by ooo
Dura-Ace:
4550170852481 - IFCR9200MX66 - FC-R9200 46-36T 160.0 mm
4550170852436 - IFCR9200AX66 - FC-R9200 46-36T 165.0 mm
4550170852443 - IFCR9200BX66 - FC-R9200 46-36T 167.5 mm
4550170852511 - IFCR9200CX66 - FC-R9200 46-36T 170.0 mm
4550170852528 - IFCR9200DX66 - FC-R9200 46-36T 172.5 mm
4550170852467 - IFCR9200EX66 - FC-R9200 46-36T 175.0 mm
4550170852504 - IFCR9200FX66 - FC-R9200 46-36T 177.5 mm
Ultegra:
4550170852535 - IFCR8100MX66 - FC-R8100 46-36T 160.0 mm
4550170852429 - IFCR8100AX66 - FC-R8100 46-36T 165.0 mm
4550170852474 - IFCR8100CX66 - FC-R8100 46-36T 170.0 mm
4550170852498 - IFCR8100DX66 - FC-R8100 46-36T 172.5 mm
4550170852450 - IFCR8100EX66 - FC-R8100 46-36T 175.0 mm
Ritxis
by Ritxis
ooo wrote:
Tue Sep 05, 2023 2:36 pm
We are still more interested :mrgreen: :mrgreen: in knowing the compatibility of the 12 levers (GRX-105) with the previous 11 rear derailleurs.....
jayjay
by jayjay
robertbb wrote:
Wed Sep 06, 2023 8:03 am
Because these chainrings are made for racing.
Ritxis
by Ritxis
[/quote]
:thumbup:
:beerchug:
or rather that the 105 group is for a more "quiet" cycling, which does not mean that you cannot compete with it.....
satanas
by satanas
^ Sounds about right... :roll:
Presumably that means we won't be seeing anything in the foreseeable future here - just like everything else really. Sigh.
Matte86
by Matte86
If then the 9200 FD is cleared for using it with a 46-36, would then be possible to use it with the new GRX 12s rings? 46-30?
Thanks
harblhat
by harblhat
The listed capacity is 16T, so 46-30 should work. However a 30T small ring is not explicitly supported by Shimano.
Matte86
by Matte86
harblhat wrote:The listed capacity is 16T, so 46-30 should work. However a 30T small ring is not explicitly supported by Shimano.
I see.. thanks for you reply.. I’m just thinking a work around for using the new GRX making it Di2 as a 11-34 would be sufficient for my riding
ultimobici
by ultimobici
They won’t work properly. You may be able to fudge them so they work acceptably but they’ll not be that slick in operation.
harblhat
by harblhat
Matte86 wrote:
Wed Sep 06, 2023 6:50 pm
It's a good option, definitely better than using third party cranks/rings. If you don't need a clutch and the 30-34 gearing is low enough for you then its totally workable.
The one potential issue is the GRX crankset chain line is 2.5mm further out than 12s road. People have been able to take this up with standard FD adjustments but I would say it depends on the frame.
pdlpsher1
by pdlpsher1
I'm running a 9200 FD along with 11-speed GRX 48/31 chainrings, but not on a stock GRX crank. I'm using a modular crankset, one where I could choose the length of the axle. Hence I'm on par with the 9200 chainline. Prior to getting the modular crank I was using the stock GRX crankset but with 2mm chainring washers that offset both chainring inboards. The unique GRX chainring mounting system (8 bolts total) makes inboard chainline adjustments possible.
robertbb
by robertbb
Found a pic on a Japanese website.
Of note, it appears the chainring is non-series - it's not branded Ultegra or Dura Ace and shape of the spider arms looks like it may work with other Shimano 110BCD cranks as they aren't a "perfect" match for the crankarms as pictured:
