Tyre liner with tubeless
Bit of a random one but just been reading this article
https://www.bicyclerollingresistance.co ... ire-liners
and was wondering whether you could use them with a tubeless setup?
Everything indicates that it's for tubes, but what's stopping one using them for a tubeless setup to reduce the likelihood of punctures full stop. Thanks
My issue it's tyre inserts is what to do if you do actually flat.
I'm testing various things on my bike for Basajaun in July and if I get a puncture that won't seal, then I have to remove the liners and insert an inner tube to carry on, and either throw away the liners or needlessly carry them for however much further. A tyre liner seems like a better solution to reduce the likelihood of flats fullstop.
those liner cores are designed to be ridden flat so you can limp home. Probably not a good idea for your use case."Basajaun" since that is more a bikepacking thing.Knightyboy27 wrote: ↑Sun Jan 08, 2023 11:07 pmMy issue it's tyre inserts is what to do if you do actually flat.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Glue, or double sided gorilla tape, who knows, was just hoping there'd be a way of running my favoured tyres but increasing the puncture protection without sacrificing too much RR.
Your barking up the wrong tree. That is all I know. There is no amount of glue that is going to hold this thing to the tire. There is no glue that would hold it either. You could always put a tube in your tire, along with the liner, and hope for the best.
I know people really put an effort on flat tires. Either I just do not have many or I just do not think it's a big deal. 2022, I had no flats. 2021, I had a lot.
Tyre liners used to come in two flavours:
1. Thin, relatively supple. These increased puncture resistance somewhat (with especially thin/crappy tyres) and didn't totally wreck rolling resistance
2. Thick, not so supple. More puncture resistance, but more rolling resistance too, plus problems with tube holes at the joint from abrasion
FWIW, I used the first sort in the (truly terrible) Wolber 32-369 AM tyres decades ago, but only because no other tyre existed. They did the job, but a better tyre would have been the preferred option; I hate tyre liners.
If you're actually getting lots of flats - rather than just being a bit paranoid! - I'd investigate tougher tyres and/or better/more sealant.
What is the worst case in terms of terrain on the Basajaun route? Can you run a wide slick or will you be running something with knobs? Either way just run armored tubeless without liners and bring plenty to DynaPlugs and spare tubes.
Aka if you buy Maxxis tires, get SilkShield instead of EXO casing tires. If you buy WTB tires, get SG2 instead of TCS, etc etc.
Use Orange Seal, and plenty of it.
Thanks all, appreciate the feedback.
Was worth a shot but I guess as Tobin said, just got to roll with it, find some tough tyres (and yes, I think with knobs) and stock up on DynaPlugs etc.
Don't give up yet.
https://www.cyclingweekly.com/products/ ... -your-bike
Tire liners are a difficult topic for me. I like the added protection, and the run flat function (although that is limited).
However, they can be a b*tch to remove. Had them (Tubolight) installed on a wide 27.5" wheel with Conti RaceKing Protection installed. Those sat all year in a corner as they are my winter wheels. Tried to check on the sealant yesterday (still liquid mostly), but took my ages, and a tool to get the bead unstuck. Once I got the tire liner to lift out of the rim bed, it was super easy to remove the tire. On a long winter ride, I would have probably needed a taxi, if I had flatted and didn't get it to seal.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Tire liners and rim liner/tire insert are different. Dunno which the OP meant now, but the old tire liners that went between tubes and tires were crummy.
I think some good Schwalbes, a tire insert, and plugs would be pretty bombproof if you really want to play it safe.
