New GRX this year?
RDY
by RDY
If 11/36 is the best they have in terms of low gears, without going to the MTB cassettes and 1x, that's pretty shitty. They could easily do an 11/40 or 11/42 12s.
If not, it looks like GRX 11s will remain superior for 2x where range is needed.
ultimobici
by ultimobici
RDY wrote:
Sun Nov 13, 2022 10:44 pm
Not sure I follow. If you're using 1x I can see the need for bigger than 42, but why would you need anything bigger than 11-36 with 2x?
I have limited movement in one ankle and have not needed lower than 30x36 on steep off-road tracks.
calleking
by calleking
Would it be possible to combine GRX DI2 shifters with Ultegra 8100 or DA 9200? I would rather use those instead of Ultegra ST-R8170 and Dura-Ace ST-R9270 since the ergonomics of GRX are next level in my opinion.
2023 Wilier Rave SLR
2022 Wilier Filante SLR
2021 Cannondale Scalpel Carbon 2
ultimobici
by ultimobici
calleking wrote:
Mon Nov 14, 2022 8:59 am
Not until they have a 12 speed GRX Di2.
calleking
by calleking
ultimobici wrote:
Mon Nov 14, 2022 9:03 am
Yes of course, but that is surely coming considering the number of retailers that are already listing GRX 12 speed. It has been mentioned in this thread a few times now:
viewtopic.php?f=4&t=169467&p=1777184#p1777184
Anyway, just letting everyone know what is on my wish list :mrgreen:
ooo
by ooo
It doesn't say "di2" anywhere on those
screenshots.
Looks like availability was reversed to reduce self-competition:
105 electronic first
GRX mechanical first
RDY
by RDY
ultimobici wrote:
Mon Nov 14, 2022 6:23 am
Good for you. But South East England - or England at all outside the Pennines - isn't exactly noted for its vertiginous relief, and there aren't *any* long climbs. That does not make it so of all other places.
ultimobici
by ultimobici
RDY wrote:
Mon Nov 14, 2022 8:40 pm
Were I still living in the UK, you'd have a point. But I'm in the foothills of the Dolomites.
It was built with italy in mind. Climbs here are somewhat steeper & londer than in the UK and a little looser surfaced to boot.
satanas
by satanas
Not everybody is carrying nothing or racing. When you're bikepacking and it's 25+% with water bars and eroded fire trails 30x36 is often not low enough. 26x42 or 28x44 or similar can be very useful, and even Jay Petervary used 46x30 + 11-42 to win the Tour Divide, and he's not a spinner. Racers (and ex-racers) consistently fail to understand that low gears can be useful to others, and this hasn't changed in the last 40+ years...
robbosmans
by robbosmans
Because that’s quite a niche market. And you can always swap out a crankset for something with smaller gearing.
David12345
by David12345
satanas wrote:
Tue Nov 15, 2022 9:21 am
Yep, spot on. Hell, even in a hill climb race I've gotten use out of my "extremely low" 34f/40r gear and not only did I not finish last (I finished right around mid pack both for my age group and overall), but I overtook a few people who I could clearly see were struggling and grinding at a too low cadence. And this was a literal race, so if I was trying to do an endurance ride over that climb, I could certainly benefit from an even lower gear. So when I read posts on forums when random people try to declare things like "nobody needs a lower gear than X" without knowing anything about a person's fitness, preferred cadence, intended usage and terrain, I just laugh.
RDY
by RDY
The attitude seems to be worse among club racers than people at the sharp end. A few people vying for places at big gravel races consistently use 50/34 and 11/42 or 11/40. If you look closely at photos you'll see quite a few SRoad 11-42 cassettes being run with standard compact road 2x chainsets. SRoad being popular as they're way lighter than XT 11/42, and for courses that demand it, it's better than XTR where the max is 11/40. I'm tempted to order one to try it. Same phenomenon on road ... club guys who barely ever see mountains will whine about big cassettes whilst pros and their teams plead with Shimano and SRAM for bigger cassettes so they can spin smaller gear - they were resistant for years as larger cassette range = more metal and more costly and time-consuming to make.
Woland
by Woland
It's a macho thing.
ooo
by ooo
ultimobici wrote:
Sun Nov 13, 2022 3:43 pm
There is no such thing as Micro Spline Road. It is Micro Spline. End of!
freehub body is tagged MSR, as you can see on Niekgeerts pics. it is also called "micro spline road" in dt catalogs:
Shimano Micro Spline Road cassette mount, material: aluminium, design: light with standard bearings, with end cap
Size: 12 x 142 mm Colour: Black Weight: 54 g PU: 1 kit
EAN/UPC: 7613052387512
Manufacturer number: HWYABL00S1960S
recommended Retail price: €72.90
Shimano Micro Spline Road cassette holder, material: aluminium, design: light with ceramic bearings, with end cap
Size: 12 x 142 mm Colour: Black Weight: 53 g PU: 1 kit
EAN/UPC: 7613052387505
recommended Retail price: €137.90
ultimobici
by ultimobici
ooo wrote:
Sat Nov 19, 2022 5:43 pm
Still not conclusive that Shimano are introducing a new 12 speed freehub. Why would they? They have 12 speed cassettes in 10-45 & 10-51 already. Why introduce a whole raft of cassettes that require a new standard? Unless the top sprocket on the current MS doesn't line up in the same position as the road 12 speed? But bearing in mind how close they both are to the dropout, it's unlikely to be that.
This is far more likely to be DT main their wheels compatible rather than a new standard.
