Fitting SRam flatmount calipers on a 2016 Crux: Compatibiliy ?
LouisN
by LouisN
Looks like I forgot something :? ....
I'm new at disc brakes...I didn't think there was so many standards, man !
Can anyone lead me to the correct bracket adaptor on the Specialized Crux Expert EVO 2016, to install some SRam Apex1 Hydro HRD flatmount calipers ?
The rotors would be 160 mm front, 140 mm rear.
Thanks for the help :oops: :beerchug:
Louis :)
Karvalo
by Karvalo
These guys make flatmount adapters for a post mount frame but you'll need to check they fit. Not sure if there are any other options.
https://www.assolutions.ca/flat-mount-c ... ter-guide/
LouisN
by LouisN
Super !!Thanks for the link Karvalo :beerchug: .
I even found a bike shop that hold these parts (through talks with gravel aficionados friends) !
Louis :)
expatscot
by expatscot
The assolutions are the only adapters that work.
Else you could try the Hope RX4 (Sram flavour) brakes with your Apex levers.
Look 695 aerolight eTap 11
Boardman TTE eTap 11
Brompton S2 LX ti custom
Trek 5500 1994 Sram Red 10
Boardman CXR9.8 eTap 11
Open UPPER - DA 9270
Ridley x-fire Sram Red 10
and lots of non- WW others.
