Seller confirmed it's 3 bolt and it weighs 627g with the chainrings. Would that be Red 22 or Force 22?TobinHatesYou wrote: ↑Tue Jun 28, 2022 11:57 pm30mm spindle, but can’t be sure if Red 22 or Force 22. Also unsure if 3-bolt or 8-bolt.
New powermeter rumours
GPLama has a review up of the new Stages dual-sided powermeter on a Shimano 9200 crankset... and it doesn't suck!!
He's only had it on three weeks, but it tracks in-line with his Assioma Duo pedal powermeter and his Wahoo Kickr 6 trainer. There are signs of very slight spiking on the first second of sprints, but these are very minor compared to the horror show that was previous Shimano powermeter cranksets.
Overall a very positive review. Interesting to note the change in design on the powermeter itself with some bracing of the powermeter onto the right crank arm. This seems to be the magic elixir to getting accurate results.
https://www.youtube.com/watch?v=H1YxXidWZc4
After years of RnD they finally managed to get it right. It took way longer than expected tho.EvilEuro wrote: ↑Tue Nov 29, 2022 4:12 pmGPLama has a review up of the new Stages dual-sided powermeter on a Shimano 9200 crankset... and it doesn't suck!!
2016 Felt AR2 Di2
Retired:
2017 Giant TCR Pro 2
2015 Cannondale Synapse 6
Retired:
OK. So the 4iii factory install is with the flawed R-side measurement?TobinHatesYou wrote: ↑Wed Nov 30, 2022 9:34 am
4iiii has not started selling right-side power meters based on the Shimano 12-speed road crankarms.
They don't offer factory install for the 8100/9200 12-speed cranks. Only on the old cranks, which has the flawed r-side measurementLOWIEV wrote: ↑Wed Nov 30, 2022 1:34 pmOK. So the 4iii factory install is with the flawed R-side measurement?TobinHatesYou wrote: ↑Wed Nov 30, 2022 9:34 am
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
Looks like Shimano added a bunch of mass to the cranks
R9100 = 615gr (50/34 Shimano #s)
R9200 = 685gr
R9100 PM = 685gr
R9200 PM = 745gr.
(note the weight difference of the Shimano PM varies ring size to ring size it's either 60 or 80gr - that might indicate that the PM use a different casting than the non-pm, inferring the 4iiiiiii and Stages solutions won't be as accurate at the Shimano)
They really stuffed up with their left only Precision III (now 12 months old). They need to sort that out before even thinking about the right side.TobinHatesYou wrote: ↑Wed Nov 30, 2022 9:34 am4iiii has not started selling right-side power meters based on the Shimano 12-speed road crankarms.
RE: Stages nailing it. This shows it CAN be done, which made me happier than it really should have. This now puts Shimano is a really awkward positon of holding a total banana of a power meter for the 9200/8100 series. I don't see them changing over to a Stages 'wrap around' and admitting their banananess.
Do the current new stages have any issues with voltage regulation? As another forumer here pointed out that the batteries are not properly regulated so the fluctuating voltage may/may not heavily skew the reading of the ADC.gplama wrote: ↑Fri Dec 02, 2022 1:04 pmThey really stuffed up with their left only Precision III (now 12 months old). They need to sort that out before even thinking about the right side.TobinHatesYou wrote: ↑Wed Nov 30, 2022 9:34 am4iiii has not started selling right-side power meters based on the Shimano 12-speed road crankarms.
Does anybody happen to knw when to expect a Quarq DUB DFour powermeter for 9200 chainrings? Thanks ....
2023 Cervelo S5, size 56, sapphire/ice
Ok, thanks for the info. Do you have a picture please?
EDIT: Found it here: https://www.trainerroad.com/forum/t/new ... 68?page=19 Post 363
or here: https://powermetercity.com/faq/what-shi ... wer-meter/
