Canyon Ultimate CF SL7
Anybody got one?
I am thinking about getting one in the next few months with cable 105 7100.
Don't have the money to spend on a new bike that is a higher level and this is reasonable weight, a bit aero and has discs.
Heavy wheels but I have some WR50s I can use.
They list tyre clearance of 32mm. I wonder if anyone can confirm?
That should cover 30mm on my WR50s.
What are they like to ride? Stiff enough, climb well, comfy?
Will be coming from a 2012 Cervelo S5 and 2013 TCR.
Maybe you can find some answers here?
viewtopic.php?f=3&t=169994
Thanks.jayjay wrote: ↑Mon Mar 25, 2024 9:01 amMaybe you can find some answers here?
Beautiful! Thanks for your help.rawjunk wrote: ↑Mon Mar 25, 2024 9:48 amhttps://youtu.be/w_IYR_6T9-A?si=fkccvjgSKmpb1ycI
Tyre clearance shouldn't be a problem.
Have you considered the Supersix with the same groupset? It's a better bike.warthog101 wrote: ↑Mon Mar 25, 2024 8:30 amAnybody got one?
https://www.cannondale.com/en/bikes/roa ... rsix-evo-4
I have indeed. It is Orange in 105 which I don't mind as it is visible.BenCousins wrote: ↑Mon Mar 25, 2024 8:13 pm
It is however $1100 more and I am liking the tyre clearance on the Canyon.
Interested in why you say the Cannondale is a better bike?
I read this and the cheaper Canyon seemed a good deal;
https://escapecollective.com/the-prince ... fr-review/
There's three colors for the 105 build. I have the black one.warthog101 wrote: ↑Mon Mar 25, 2024 9:22 pmI have indeed. It is Orange in 105 which I don't mind as it is visible.BenCousins wrote: ↑Mon Mar 25, 2024 8:13 pm
Why is it better? I had an Aeroad, which shares the same cockpit as the new Ultimate. It's horrible. The bearings last no time due to water ingress. It only comes in limited sizes, it's hardly adjustable at all. You cannnot swap it out for anything else. The options to upgrade and lighten the Supersix are much larger. Mine is now close to 6.8kg.
You've also got exposed cables on the Ultimate and integrated on the Supersix. The Supersix measures as more aero than the Ultimate according to Tour magazine.
Canyon is direct to consumer. If you have any issues (like I did with my Aeroad), you have to wrestle with their customer servive, parts have to be mailed and you have to take the bike to one of only a few service centers. It took months to get simple things fixed. I found the Canyon customer service team to be very rude.
With the Cannondale you can by from a bike shop and get better presales and aftersales support.
Pretty sure the 7100 mechanical comes the Canyon H36 cockpit not the Aeroad adjustable ones.BenCousins wrote: ↑Mon Mar 25, 2024 10:28 pmThere's three colors for the 105 build. I have the black one.warthog101 wrote: ↑Mon Mar 25, 2024 9:22 pmI have indeed. It is Orange in 105 which I don't mind as it is visible.BenCousins wrote: ↑Mon Mar 25, 2024 8:13 pm
I would be considering the outgoing TCR Advanced, seems you can pickup the 7100 mechanical for about $3k AUD or the Di2 version for about $3500ish. The Advanced level now has a full CF fork but is a normal sized steerer.
Probably not as aero as the Ultimate but I guess you could add a one piece bar of your choice later.
You have more experience than me then, thanks for the feedback.BenCousins wrote: ↑Mon Mar 25, 2024 10:28 pm
The exposed cables I see as a positive in a cable operated groupset. I see less tight turns making a better shift and replacing cables potentially easier.
Ditto with replacement of stem and bars. An advantage removed and a big negative if you cant change the cockpit.
I assume the tyre clearance is still pretty good on the Supersix? I like that blue too, but haven't seen it listed in Aus.
Not too concerned by lack of a bike shop. Happy to do my own work, but sh it service sounds no good and hadn't heard that previously.
"better" is subjective but the Cannondale is ugly so it's got that.BenCousins wrote: ↑Mon Mar 25, 2024 8:13 pmHave you considered the Supersix with the same groupset? It's a better bike.warthog101 wrote: ↑Mon Mar 25, 2024 8:30 amAnybody got one?
I am still leaning toward the Canyon. 1100 is a lot less to get past my wife
I am pretty sure I can make the Canyon in a size L work for me.
With a face like mine, what the bike looks like is the least of my worries , both are fine imo.
The shifting is perfect in the 105 Cannondale. I went from a Canyon with EPS and the shifting is just as good.warthog101 wrote: ↑Tue Mar 26, 2024 1:58 amYou have more experience than me then, thanks for the feedback.BenCousins wrote: ↑Mon Mar 25, 2024 10:28 pm
I'm also happy to do my own work, but I'm talking about the list of problems Canyons typically have with things under warranty that you shouldn't have to do yourself. On the Aeroad alone
- Recall of the original adjustable bars after the MVDP failure
- Noisy seatpost clamp that also needed a redesign
- Saddle clamp that is notorious for getting stuck
- Current recall on frames (see the Aeroad thread)
Canyon were bought out by private equity in 2020. They are now focussing on:
- Bikes that look good on the website
- Pro sponsorship (they just signed MVDP for TEN YEARS - do you honestly want to pay for that?)
- Social media marketing
- Bikes that are cheap to manufacture in volume at the detriment of important elements (like component swapping and adjustment)
- The customer service has taken a massive nosedive. In 2008 I had a crack in the bottom bracket of my Ultimate CF, I drove to the Swedish distributors and he gave me a new frame (a more recent model). In 2023 I had a series of small issues with my Aeroad. Each time I had to make a booking in a local workshop that Canyon had licensed to work with them. Each time I arrive and they don't have the parts or I have to wait a week for the 'Canyon mechanic' to turn up. When I press customer service (who aren't even in Sweden anymore) they are rude and dismissive. I sold the bike in the end at a €3k loss because I couldn't compete with an unreliable machine.
Money guys are in charge, the original founders are not involved. The company is going downhill fast to a high volume mass market model. I'll do everything I can to prevent people using this brand.
You definitely don't like them @BenCousins
Thanks for the feedback.
Difficulty in adjusting handlebar reach and width is my biggest concern.
The Finance Minister isn't happy at the moment with a new bike.
Have a spa to fence and get a permit for first. On hold for a while and the Supersix is back on the list.
