here's mine mounted. a tad long, but really solid.iamraymond wrote: ↑Wed Feb 28, 2024 11:38 pmDepending on your stem you might be able to find one made by ccache.
https://ccache.cc/collections/computer- ... _by=manual in
I sort of doubt they make they're own products, but I have no idea who their supplier is.
By the way here are some pictures sent by Pandabuy who are facilitating my order. I haven't received the part yet so I cannot show it installed.
Famous AliExpress parts!
Could someone please share the link for the RYET saddle, 142 mm wide, eva finish? Thank you very much !
2023 Cervelo S5, size 56, sapphire/ice
- racingtiger
- Contact:
Do any of these companies make something similar to a short sleeve Gabba jacket?
NOW WITH MORE FLAVOR THAN KOOL-AID!
I'm 129 lbs! How's that for light!
Is that the Bolt or Roam?
OK cool. I have a Roam v2 so it should fit better with the larger device.
If you want some cheap kit for turbo rides or short outdoor rides, you can snap up some bargains. There are even some decent fabric jerseys out there, but what you won't get is decent technical kit. You won't find anything that performs even 50% as good as a Gabba.racingtiger wrote: ↑Thu Feb 29, 2024 6:30 amDo any of these companies make something similar to a short sleeve Gabba jacket?
If you're in the UK, Wiggle are basically giving away Gabba's in certain sizes. Plenty of other Castelli kit going for cheapgloscherrybomb wrote: ↑Thu Feb 29, 2024 10:22 amIf you want some cheap kit for turbo rides or short outdoor rides, you can snap up some bargains. There are even some decent fabric jerseys out there, but what you won't get is decent technical kit. You won't find anything that performs even 50% as good as a Gabba.racingtiger wrote: ↑Thu Feb 29, 2024 6:30 amDo any of these companies make something similar to a short sleeve Gabba jacket?
The reasonable quality stuff from aliexpress stops at summer stuff. The technical/winter gear is still all garbage from what I've seen.
Depending on the temperature, I have no issue at 0~10 C with Jakroo winter bib + jacket + base layer + rainproof layer (Gorewear shakedry / Decalthon Ultralight), but will wear Trek Circuit Softshell instead of Jakroo stuff, which is only slightly thicker than Jakroo jacket, at -5~5 C or strong windy cold day.
Are they from aliexpress?
