New Look 795 Blade RS
Amazing, enjoy the ride!
Ridley Helium SLX - RIP https://weightweenies.starbike.com/for ... lit=ridley
Scott Foil - current viewtopic.php?f=10&t=173046&p=1813155#p1813155
Love the return of the iconic Mondrian paint job!
Sent from my Pixel 6 using Tapatalk
- MrCurrieinahurry
- Moderator
Hot damn thats stunning
Basso Diamante eps 12
Ride is surprisingly comfortable! Coming from a 2nd gen Supersix Evo and more recently Tarmac SL6 Ultralight, I would say it's more comfortable than the S6 and on par with the SL6. Some of that may be due to the tires (28mm vs 25mm). It generally feels faster overall and more stable descending than the SL6. Those are my preliminary thoughts on ride feel/quality.
Some weights:
- Frame: 970g (size M, including bottle cage bolts and derailleur hangers)
- Fork: 416g (uncut)
- Seatpost: 100g (no hardware)
- Stem: 96g (90mm, no bolts)
- Handlebar: 221g (420mm)
- Expander plug: 40g
- Seatpost clamp: 25g
- Headset cap: 12g
- Headset bearings: 43g
- Thru axles: 62g (front and rear)
Some cons: frameset heavier than SL8/gen 4 supersix, framesets come with pre-defined stem lengths and handlebar widths (M = 100m stem, 420mm bar)
Pros: build quality and finishing of the frame seems top-notch, w/ tight tolerances, and everything seems well engineered / thought out. Example: the handlebar has 2 exit ports for the internal cable routing to the shifters - one for Shimano and another for SRAM - so the hydraulic hoses have the shortest, smoothest connection to the shifter. Lifetime frame warranty. Classic Mondrian paint scheme. Horizontal top tube, but w/ dropped stays.
I was on the fence between the gen 4 supersix, SL8, or the new 795 Blade RS as my first 'aero' disc brake road bike. I don't think you can go wrong with any of them, but I'm happy with my decision!
- Moderator
Do you have a full build brake down? You could easily go sub 6.8 with just different wheels
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
You're probably right, as the wheelset came in at 1,468g (with tubeless tape but without valves or thru axles).CustomMetal wrote: ↑Wed Oct 04, 2023 12:51 pmDo you have a full build brake down? You could easily go sub 6.8 with just different wheels
Build list:
Look 795 Blade RS Frameset (size M, 90mm stem, 420mm bar)
Seatpost: Look Aeropost 4 Carbon, D-shape, 350mm, 13.5mm offset
BB: Ceramicspeed T47 internal
Crankset: THM Clavicula SE power meter, 172.5mm
Chainrings: Carbon-TI EVO 12sp 52/36
Chainring bolts: Carbon-TI X-Fix
Cassette: Dura-Ace R9200 11-30
Chain: Dura-Ace M9100
Front Derailleur: Dura-Ace Di2 R9250
Rear Derailleur: Dura-Ace Di2 R9250, with Ceramicspeed OSPW
Shifters: Dura-Ace Di2 R9270
Brake Rotors: Galfer 140mm Centerlock w/ Galfer pads
Saddle: Berk Lupina Short 132mm
Bar Tape: Supacaz Super Sticky Kush Galaxy – White
Wheelset: DT Swiss ARC 1100 DICUT 50mm DB
Tubes: RideNow TPU Road Light Inner Tube
Tires: Vittoria Corsa Pro Control 700 x 28mm
Pedals: Speedplay Nano
Bottle cage: Carbonworks
