I need a pf30a to shimano 24mm bottom bracket, a friend has a c-bear pf30a-gxp-r ( essentially the same as the shimano version with a small shim)
im wanting to know if the shim is removable and able to be used with the 24mm shimano crank ?
Cheers
C-bear pf30a bottom bracket q's
