I'm piecing together a crankset with Red AXS arms, quarq PM spider, and a wolftooth 1x chainring.
Does anyone have a source on the lightest bolts to replace the 8 DM bolts and the 4 chainring bolts?
thanks!
Lightest DM and chainring bolts for SRAM Dub crankset?
- eucalyptus
Chainring bolts, any 7075 alloy bolts from Aliexpress should do just fine.
Or if you fancy yourself Carbon Ti bolts, same stuff as Ali but 5x the price. I ordered 6.5mm bolts but they are rather short with a Garbaruk 1x chainring, so waiting for 8.5mm bolts to see if make a better fit.
The 8 bolts holding the spider, why would you like to replace these? Weight, I mean... I do not think these would be the bolts you would try to make lighter. They are one of the most critical parts holding it all together. But if you wanna save 3 grams then titanium bolts would do with the risk of corrosion.
