Hi guys,
I've been using a Bontrager Aeolus saddle in 145mm and I'm quite happy with it except the weight.
I was looking for a new saddle and made my choice for the alpitude gardena because it shape is similar to mine but now I'm wondering if I should choose the 140mm or the 150mm. My seatbones seems to be around 115/120mm.
Any input would be appreciated.
Thanks
Saddle width
Seatbones + one centimeter each side, so the 140 mm one._scott_ wrote: ↑Sat Jun 25, 2022 12:20 amHi guys,
Thanks
Seatbones + one centimeter each side, so the 140 mm one. It is very important, if you made a good measurement._scott_ wrote: ↑Sat Jun 25, 2022 12:20 amHi guys,
Thanks
That's not always the case though. You could need to add more or lesss depending on the saddle design and how aggressive your position is.milanv wrote: ↑Sat Jun 25, 2022 6:05 amSeatbones + one centimeter each side, so the 140 mm one. It is very important, if you made a good measurement._scott_ wrote: ↑Sat Jun 25, 2022 12:20 amHi guys,
Thanks
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
My position is pretty agressive. I have 9cm height difference between the saddle and handlebar. Previously I tried selle italia slr kit carbonio 131mm and Fizik arione versus evo r1 132mm. I hated the flex in the cutout part of the selle italia and had some occasional numbness. The Fizik also gave me some numbness and some chaffing near the perineal area.Roadbiker10 wrote: ↑Sat Jun 25, 2022 9:47 amThat's not always the case though. You could need to add more or lesss depending on the saddle design and how aggressive your position is.
The 145 aeolus was the only saddle that has been trouble free and that's why I'm thinking of going 150 instead of the 140.
- wheelsONfire
Go for the wider. A wider saddle is mostly less of an issue than a too narrow._scott_ wrote: ↑Sat Jun 25, 2022 12:13 pmMy position is pretty agressive. I have 9cm height difference between the saddle and handlebar. Previously I tried selle italia slr kit carbonio 131mm and Fizik arione versus evo r1 132mm. I hated the flex in the cutout part of the selle italia and had some occasional numbness. The Fizik also gave me some numbness and some chaffing near the perineal area.Roadbiker10 wrote: ↑Sat Jun 25, 2022 9:47 amThat's not always the case though. You could need to add more or lesss depending on the saddle design and how aggressive your position is.
Bikes:
Open *UP* (2016.04.14)
