robbosmans wrote: ↑Mon May 23, 2022 5:11 pm
I am getting flashbacks to the Dura ace thread… Please keep it civil.
Similar, but I see the discussion to revolve more around amateur which is the target group of 105.
IMO,Reduce gearing to fit better with vast amateur make sense. Anyone need 53t can increase the budget to ride Ultegra/Dura-ace. A win for Shimano.
blaugrana wrote: ↑Mon May 23, 2022 3:38 pm
I don't think I've ever seen anyone (pro or not) average 120 or 130 rpm of cadence in a TT or any kind of sustained effort in a race. Of course it's possible to do it, just like it's possible to climb at 50 rpm for hours, but there is no reason to if you can pick your gearing to avoid it. And for many people, that's slightly larger chainrings than for others, there is nothing wrong with that.
Yeah, 120-130 is more like sprint cadence. But if they can do high power sprint at that cadence, they can do high power short seated-acceleration before the tuck down hill as well.
blaugrana wrote: ↑Mon May 23, 2022 5:30 pm
Also, it is worth noting that due to the non-linear relation between speed and power, the speed differentials between a well trained amateur and a professional will be a lot more similar at the top end than at the low end, so the same can be said for their gearing needs. For example, a 30% (just a somewhat reasonable example) increase in power will produce a much higher % of extra speed when both are on a very steep climb compared to when they are pedalling fast downhill on rolling terrain.
hmm, right. Amateur at half the power of pro (200w vs 400w) maybe 100% slower up hill (half the speed) but ~26% slower down hill? (1.26^3 ~=2.000376)
So, a scaled down pro gearing for amateur would be ~26% lower top end and 100% lower low end, right?
