How do you minimize tubeless tire runout when mounted?
What are people doing to minimize tubeless tire radial runout once mounted to the wheel?
I have used several different tubeless tire & rim combinations and I always have tire radial runout that is visible to the naked eye.
I have been using a mixture of Dawn dish soap & water to help install the various tires [because they were all difficult to mount], but should I be using something slicker? Silicone spray, other? Am I just bad at tire mounting??????
I have never taken the time to measure the radial runout, but I would say that it appears to be 3 to 6 mm peak-to-peak.
The current combination is DT Swiss GR1600 wheels [23mm inner width] with Continental GP5000 TL 700x32. The tires need to be replaced for spring so I have plenty of time to practice mounting & sealing to minimize radial runout. Most likely going to use GP5000 S TR 700x32.
Two wheelers rock!
did you get popping sound, because when I didn't hear that, the tire has indicator line around the rim and is recessed one spot although the tire is inflated.
Yes, popping sounds occured.PoorCyclist wrote: ↑Sat Jan 22, 2022 4:16 amdid you get popping sound, because when I didn't hear that, the tire has indicator line around the rim and is recessed one spot although the tire is inflated.
Two wheelers rock!
No noticeable runout on any of my tires. One of my 35mm Continental Terra Speeds has a sideways kink in it, but I can't feel it at all... it's just a visual annoyance.
Hutchinson Fusion5, Conti GP5KTL, Tufo Thundero, Speedero, Panaracer Gravel King SK.
Haven't noticed any runout.
Maybe overinflating until the tire is evenly seated helps.
Of course you need to deflate afterwards
Check the tires with tubes on none tubeless rims too.
Most tires have *some* runout.
And I've noticed it getting worse over the last few years, or that might just be me buying cheaper tires.
That's crazy. If you're getting that on several different tyres then you're either not inflating them enough to seat the entire diameter of the bead, you're doing something else seriously wrong, or you're imagining a runout that doesn't actually exist.
I'd say either post video of it or just take them to an LBS to see what's happening.
Not fully seated.
Yep, 100% operator error at the mounting stage.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
- MarshMellow
The taping job on these rims is the problem. Have one set of tires which will not seat if cloth rim tape is installed, all same brand of tire.
Check the runout at the bead area. Usually, there is some type of seam at that area and if it is not seated, you will notice it. If both beads are seated AND there is a run out at the outer most diameter of the tire, then it's the tire.
3-6mm is a lot.
3-6mm is a lot.
Indeed, there has been operator error! I may be one of the worst tubeless tire mounters out there .
I stopped by my LBS yesterday and they put my wheels on the truing stand. They confirmed that the wheels are straight, but the tire mounting was whicked wonky. They suggested:
1) removing the valve core
2) using a pistol grip blow gun to seat the tire, with compressor pressure set at 90 psi, as this is how they seat tubeless tires
Thus, that is what I will try next. I can inspect the rim tape when the tires are off as well.
Two wheelers rock!
