What, no it doesn't. AirTags are over 1-1/4" in diameter.
Apple Airtag as a Bike Tracker
My thoughts exactly.TobinHatesYou wrote: ↑Mon May 16, 2022 6:27 am
Okay so AirTags are actually pretty huge and this obviously won't work with road tires. The minimum recommended tire width is 38mm, and I still wouldn't run one of these. Low pressures plus rocks, roots, drops, etc. = bottoming out the tire. If you flat, you break your fancy AirTag holder and there is an elevated risk of damaging your rim.
Another success for AirTags today.
A teammates Venge was stolen last night and has been recovered by the police, found in a stolen Land Rover.
IG: RhinosWorkshop
IG: RhinosWorkshop
I use this: https://www.shopmoment.com/products/cur ... r-airtags/scottydonald wrote: ↑Mon May 16, 2022 8:19 pm
Everyone around you has had good luck with them, how have you and your friends been mounting them to the bike?
Stuck to the inside of my DT, accessible via the cover shown below.
Bumping old thread, want to put a couple smart tags on my bikes. After 1 year, any new good ideas to mount them to the bike out of sight? I like the unused di2 junction somewhere in the frame.
Sticking a radio inside a metal or carbon tube is going to result in massive attenuation. The only reason it works OK in my frame is because the door is made of plastic...and even then it reduces its effective range significantly.
Thinking of buying this one but I have a Romin Evo 3D. Will this fit as well/is the SWAT the same?
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
