Easiest pedals to clip into?
I'm very light and have seen people complain it makes it harder to clip in. I need a new pedal for the new bike and thought I'd finally try clipless (or one with both sides or the ability to use trainers if needed)
Any suggestions? Even the speedplay zero I've seen people struggle with so I'm not sure what to try
Time Xpresso is easier to clip in than my Shimano (MTB) SPD system ...
Old Speedplay Zeros have normal tension and can be slightly vague to clip into once the bodies are worn. Speedplay Light Actions have less binding tension, but they weren’t carried over by Wahoo. Look also used to have “KeO Easy” pedals, but those also seem to be discontinued.
For 3-bolt systems, Time Iclic style are probably easiest to clip into. Shimano SPD-SL are also easier to clip into than Look KeO in practice.
You’ve also got the option of using various 2-bolt systems. Crank Brothers EggBeaters are extremely easy to engage.
Easiest are the Time since they are “open” by default and “close” when you press the pedal. Quite unique and effective as concept.
- Supersix evo2 HM 5707g
- 1995 Miguel Indurain Pinarello restauration project
- R3000si Junior bike restauration project.
- Contact:
LOOK Quartz MTB pedals with properly shimmed cleats. Easiest pedal I’ve ever used and the reason why I commuted on them for years. Not that easy to find now. Luckily I have two good pairs and a few spare cleat sets. For reference, I’ve also used Shimano SPD and SPD-SL as well as Crank Brothers Candy pedals (similar to Eggbeaters).
+1 to Time pedals for the easiest clip in.
I've used Speedplay Zero, Shimano SPD SL, SPD (mountain/gravel style), Time Impact, Time RXS, and Time XPro. Time Xpro is astonishingly easy to clip in and out of. The only issue I've had, is that they don't always "rest" with the entry side up; however, that's not really been a problem for me in actual use as the pedals are quite long and easy to "flip" the right way up with the tip of my toe, if necessary.
Double sided SPD is a good system to start out with I think.
If you want to jump directly to something solid then try Look based (not necessarily look branded).
You can set the spring tension on low at first so you don't feel too awkward being "stuck". Then turn up the tension as you get used to it. Keep it low for at least 10 rides because in the beginning we tend to forget we're clipped in.
Some pedals (not systems) are just shit for beginners because the bearings are too draggy or they don't have a heavy end. That means that unclipped, the pedal can be in any position which is just frustrating. As long as it always drops to a certain position you can practice clipping in from there. With a low spring tension you won't feel awkward.
I've seen Look branded pedals with the problems I described, and Time Xpresso pedals too, not returning to the same unclipped position.
ff119 wrote: ↑Wed May 12, 2021 9:41 am
Not in any system yet.
Anyone heard of these? https://www.bythlon.co.uk/
So you're forced to use 3-bolt road shoes, and you have to walk on the cleat's "keyed" portion? At least with real walkable clipless cleats, the rear snap-in plate doesn't actually touch the ground.
You are better off just riding with regular shoes and flats.
- robbosmans
- Moderator
- Contact:
How light are you? Shimano makes a light version of their SPD SL’s, their normal mtb SPD’s can also have very little tension.
I use the Shimano PD-T8000 for commuting. Not quite WW (392g), but they have both an SPD side and a flat one. I can't really comment on whether it would be easy to clip-in as I weigh around 80kg, but it feels ok to me. You can adjust the tension if needed.
As stated previously, the Click’r pedals from Shimano (PD-T421) are supposedly easier to use. You may want to test them!
