Maybe the derailleur cables go through the bars and into the stem? That bike has a derailleur cable on the rear.
The Time Bicycles Thread -- Time Frames, Bikes, & Hardware Components After Sale To Cardinal Cycling Group
I see the derailleur cable on the black model. It's weird because you can also see the crimped cable at the derailleur on the blue model.
Also, nice choice of Princeton Wheels for the photos
The ADHX shown has the Deda Superbox stem. The cables go under the stem into a channel that allows the wires to run inside the headset and frame. This design allows for much easier setup of internally routed systems and you can use any handlebar. The stem weighs a bunch at 179 grams but it's very nice for mechanics who hate internal routing shift and brake wires.
- ArtifactsInMotion
- Contact:
There are few other brands bringing such high levels of engineering to their products, so who better? Maybe Parrington, but not nearly as striking.
'22 Orbea Orca Aero 57cm, DA92, Bontrager RSL62, GP5KSTR 28mm, Roval Rapide Cockpit, SLR Superflow Carbonio, 7.8kg
how do we date time bicycle frames? I bought a time lugged rsrs ulteam. I wondering if i bought a fake or a real one. Is there way to tell. its a di2 only black out model. Second is. i cant find if there is a weight limit on this frame. It has a ISP. and I know im stupid. I weigh 220LBS. But love those luggs.
Can. any Time lovers help??
purplecu22 wrote: ↑Sat Apr 16, 2022 1:19 amhow do we date time bicycle frames? I bought a time lugged rsrs ulteam. I wondering if i bought a fake or a real one. Is there way to tell. its a di2 only black out model. Second is. i cant find if there is a weight limit on this frame. It has a ISP. and I know im stupid. I weigh 220LBS. But love those luggs.
The serial number tells the year of the frame. It's usually the first set of numbers on the serial number decal.
Regarding the weight limit question, there isn't one on this frame.
I ride my PCWs tubeless without rim tape?
I would like to thank everyone for their help. I found a sticker on the inside of the chain stay. The S/N449XLXX. cant be the year it was made. I have a EN14 78X above the s/n.
So made in 2014. 78x production item?
It has. the pf30. and the time headset system and the weave in the fork. Where the seatmast intersects with the chain stay. I have what looks like a small clear coat lifting. The person who had it before me was tall. I will need to cut the seat mast some. LIke 4 cm. I dont see any cracks at all.
I normally do not like ISP bikes. Ive read, that the early model were flexy in the ISO to seat stay? Anyone know.
I absolutley. love the lugs and look of this bike. I have always wanted a time bike and a look 585. I know have both.
I wish the bike had the original time stem. but it doesnt. I put a eastom full carbon ea90sl.
Thanks once again for everyones help here.
purplecu22 wrote: ↑Sat Apr 16, 2022 7:47 pmI would like to thank everyone for their help. I found a sticker on the inside of the chain stay. The S/N449XLXX. cant be the year it was made. I have a EN14 78X above the s/n.
Yes, it's a 2014 model frame.
Regarding the flex in ISP frames, I have a VXRS with the Translink seattube/post and I don't notice the flex. And my frame is significantly thinner/smaller tubing diameter than your RXRS Ulteam. And I'm over 200 pounds and 6'3 if that helps at all.
And you can always get an original stem. They still offer them.
