Suggestions for an aero road round bend handlebar
It's probably really slim pickings, but I want to know if I'm missing anything.
Top of my head, for bars that were ever in production:
-3T aerotundo. Out of production, also had a ridiculous reach.
-Zipp Vuka Sprint traditional bend. Out of production and was quite rare; I have it on my bike and would be sad if I need to replace it.
-Ritchey Carbon Streem. Only in-production, non-integrated bar I could find.
-Ritchey Solostreem. Similar to above, but integrated with a -6 stem.
-Canyon H11. Integrated, and I think for 1.125 steer.
That's all I could think of. Anyone knows of anything else I'm missing. Ideal would be something in a 38 cm width, but I think that'll be quite difficult to find. I've seen Scott bikes with aero road round bend bars, but those were one-offs for their sponsored riders.
I guess there's also the Bontrager Aero in VR-CF. It could almost pass as a round bend.
Basically doesn't exist on the market now bar the Ritcheys that you've mentioned. The round bend Syncros limited run bars are also 1.25 steerer and are basically unobtanium. I'm on rotundo's and would love an aero option but it's just not out there now and probably won't exist again.
S6 Evo
S5 Aero
S5 Aero
The bar/stem combo on the new Emonda is another option, it's sort of half way between classic and ergo bend.
It's hard enough to find any classic bend bar, let alone an aero one in 38cm
Yeah, it really is too bad that manufacturers are ditching classic bends. 3T doesn't even make one anymore. I'm surprised that Ritchey is marching on with its offerings.Pierre86 wrote: ↑Mon Sep 28, 2020 5:48 amBasically doesn't exist on the market now bar the Ritcheys that you've mentioned. The round bend Syncros limited run bars are also 1.25 steerer and are basically unobtanium. I'm on rotundo's and would love an aero option but it's just not out there now and probably won't exist again.
Are you referring to this one? It really could pass for a classic bend
May just have to source a Canyon H11 (which is available in a 39 cm), though it would change my fit a bit, as it's a -6 as opposed to -17
ETA: on second thought, this might not work, as it's for 1.25 steering tube (as opposed to 1.125). Normally, one could buy a shim, but I'm not sure if it's possible. That said, it is available and is certainly a classic round bar.
You could make your own shim - 3d printed plastic would probably be fine, and quite easy.
You could even make it at a slight angle to make the stem -10° or -12° like exists for some Specialized adjustable angle stems.
If you look at photos of a complete bike you can see the the flat part of the drop is angled up quite a bit, so a shim would also improve that i.e. make it closer to horizontal.
^ That's a Madone SLR, I'm not sure if it has exactly the same bend bar as the new Emonda (bontrager xxx or whatever), but they both seem to be the next best thing to a true classic bend.
How about Prime Primavera Aero bars? Not sure if they qualify as round bend, but they are very comfortable in the drops.
They come in 38cm size and have good internal cable routing.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
They're definitely not really a classic bend, but they seem to be flatter in the drops than many others.
Kind of strange how they have that dished area behind where the hoods go, I guess it's for resting your forearms when in the aero hoods position .
that's the madone, they're talking about this one
bars: https://www.trekbikes.com/us/en_US/equi ... Code=black
bar-stem: https://www.trekbikes.com/us/en_US/equi ... m/p/32627/
it's not a super wide aero top and the drop isn't as big as a traditional bend
Yeah, the dished area makes the bars more comfortable on long rides, I like it (even though the bars are on my wife's bike, which I ride sometimes).
Overall a well designed handlebar, even has proper di2 integration, well priced too.
I think it's basically the same bend. Bontrager calls it VR-C/VR-CF (variable radius - compact/ variable radius - compact flare)bilwit wrote: ↑Mon Sep 28, 2020 9:48 pmthat's the madone, they're talking about this one
