Factor Ostro
hansotto089
by hansotto089
That's probably the most beautiful spindle powermeter combo I have seen! Too bad Elilee cranks are not available in 175.
Speaking of cranks. I seem to overlook something - please help me understand: Why don't people just stick with a Dura Ace crankset? Is it not stiff enough? Too mundane?
Can't possibly be the weight?
Let's say I want a (double sided) Powermeter.
11 speed Dura Ace with double sided 4iiii crank based PM is around 640g (in 175mm).
Rotor with P2M: 661g
- Rotor Carbon Cranks (175mm): 260g
- Rotor 30mm Road Axle: 96g
- P2M NG Eco Spider: 155g
- DA Chainrings (50/34): 142g
- Chainring bolts: 8g
SRAM Red DUB cranks & Quarq DFour PM: 656g
- Cranks & Axle (175mm): 340g
- Quarq DFour Spider: 166g
ichobi
by ichobi
You are comparing spider based pm with a double side crank arm pm. Apple to orange. The latter will always be light.
Da cranks generally scratch quite easily, not particularly light
seventyseven
by seventyseven
For me it came down to accuracy, availability and price.
Hexsense
by Hexsense
hansotto089 wrote:
Wed Jan 11, 2023 3:31 am
Switch DFour to Sigeyi Axo 4-110 for Sram 8-bolt crank to save 60 grams.
https://www.sigeyishop.com/product/axo- ... interface/
Sram DZero weight about the same as Sigeyi. But Sram intentionally make DFour very heavy for whatever reason (punish you for cheating for Shimano Chainring?). Meanwhile Sigeyi Axo 4-110 and 5-110 weight about the same (around 105g).
dudemanppl
by dudemanppl
Also swap the Rotor to a Sigeyi AXO for a 50g savings.
Lina
by Lina
Some people also prefer cranks that stay in one piece.
hansotto089
by hansotto089
dudemanppl wrote:
Wed Jan 11, 2023 6:36 am
You mean swapping the P2M?
itsacarr
by itsacarr
pipii wrote:
Tue Jan 10, 2023 2:50 pm
Finally finished my build after lightbicycle AR55 flyweight built with extralite spd3 arrived. 6.32kg with computer mount,pedals and one tune cage.
Just had to give this another thumbs up - that's an incredible looking Ostro & unique to boot. Love seeing those EXS bars. Wonder how the drop compares to the Black Inc bars.
Just ride ..
StiffWeenies
by StiffWeenies
hansotto089 wrote:
Wed Jan 11, 2023 9:09 am
I believe Sigeyi spiders are lighter than P2M SL
pipii
by pipii
itsacarr wrote:
Wed Jan 11, 2023 3:13 pm
The reach and drop of exs aerover are 70 and 125 respectively.
sworks sl8 rtp 56 5.77kg
factor ostro vam 56 6.15kg
specialized allez sprint 2023 7.13kg
retired:
Lapierre aircode 2017
specialized sl7 56 6.75kg
flmo
by flmo
StiffWeenies wrote:
Wed Jan 11, 2023 5:53 pm
Maybe that is helpful. Rotor ALDHu with Sigeyi PM
hansotto089
by hansotto089
flmo wrote:
Thu Jan 12, 2023 10:18 am
Thanks! Looks amazing. Why did you go for the Rotor chain rings instead of DA? Weight/stiffness or consistent looks?
spdntrxi
by spdntrxi
hansotto089 wrote:
Sat Jan 14, 2023 5:17 am
maybe it's AXS chainring..
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
flmo
by flmo
I chose them for weight and looks. Don't like the look of Shimano cranksets, that much. Could have gone lighter with the non-aero version, but I think the overall appearnce of the crankset outweighs the burdon of the few additional grams.
This will be combined with an Ultegra 12 speed and DA cassete. Altough not officially marketed as a 12 speed chainring, Rotor confirmed (via Facebook), that it should work without an issue, up to 54. Premier Tech team also used the same combo last year.
kode54
by kode54
Less cleaning with the aero version!
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
