Cycomanic wrote: ↑Tue Jul 28, 2020 6:43 pm
rides4beer wrote: ↑Tue Jul 28, 2020 3:26 pm
Cycomanic wrote: ↑Tue Jul 28, 2020 12:43 pm
In this months tour there was a test with the test of Petersen and that one had 216W (but they said it lost out on some aero gains). In 10/2019 they had a Madone SL6 at 2017W, but in March 2019 the SLR 9 had 212W also the Aeroad CF SL7 in that test had only 212W compared to 208W for the CF SLX Disc 9.0 in this months tour. Goes to show that much probably depends on the wheels.
We can also see that discs are less aero compared to rim bikes, pretty much all newer versions of a bike (using discs) are less aero than the older rim versions, although we would have expected there to be further optimisations.
The other thing that sticks out how much better the SystemSix is compared to all the other disc bikes (with the exception of the Cervelo S5 maybe). Again though this could be wheels, IIRC the knot wheels are 64mm, while pretty much all the others just have 50mm max.
I believe the Tour testing listed above were all on Zipp 404s, to even the playing field.
It's always funny, the old Fuji Transonic tested the same as the Cervelo S5, but never gets listed with the "fast" bikes. I'm curious to see some testing of the new Transonic, since it's supposedly more aero than the old one, and now has discs.
Normally Tour only mentions the Zipp 404 scores on the side (although recently they have done this less), so unless sigma made the table specifically from pulling the zipp values from the text I doubt it would be the scores with the Zipps (the score of the Ridley is definitely with their wheelset). Regarding the Transonic, they tested it in last months Tour, with their Oval 950 wheels it comes to 221W and with the Zipps it gets down to 216W so still quite a way from the other bikes.
But I've been a bit more doubtful about the Tour tests recently, for one Hambini in his critique of laminar flow windtunnel tests definitely has a point, but also I've found that some of the things they were writing was quite uncritical and I wonder how "impartial" they really are.
I pulled this off an old ww thread as I cannot translate the German (and it's an image so google translator did not work):
All tested at 45kph on Zipp 404s:
2019 Cannondale SystemSix Disc - 203w
2016 Trek Madone - 204w
2016 Specialized Venge ViAS - 204w
2016 Cervelo S5 - 205w
2016 Felt AR FRD - 205w
2019 Cervelo S5 Disc - 206w
2016 Canyon Aeroad - 208w
2019 Specialized Venge Disc - 208w
2016 Giant Propel Advanced SL - 210w
2016 Scott Foil Premium - 211w
2016 BMC Time Machine - 211w
2016 Look 795 - 212w
2019 Trek Madone Disc - 212w
2019 Ridley Noah Fast Disc - 213w
Interestingly, Tour somewhat declared the Ridley the winner based on value, comfort, weight, and close enough aero performance. Interesting that the 2019 venge is not in here which is probably as light (but certainly not cheap).
Lots of bikes: currently riding Enve Melee, Krypton Pro, S Works Crux, S Works Epic Evo, SL7.
In build: SW SL8
