New Giant TCR Advanced announced
Hi guys, I realize these cover stem for Giant Tcr.
***fitting only for Contact SL stem OD2 on 2021 models***
Anyone interested are for sale on ebay and I ship all over the world.
link here: https://www.ebay.it/itm/185558008015?mk ... media=COPY
If you just want to replace it, you need your rim depth + 10mm minimum / +12mm conservatively. Can get away with as little as +8, but not not every pump will have enough to bite on.
I've got the TCR advanced one with the 1/8th steerer. I really like the integrated look with the spacers, but them stem is pretty heavy (174g).
Anyone know a lighter stem that will play nicely with the spacers?
I have a fizik r1 here, and it knocks 40g off, but really just doesn't look as nice
The 2023 Giant line-up has been announced for Japan.
They're selling the Advanced Pro Disc as a frameset now.
https://www.giant.co.jp/giant23/bike_da ... d=00000010
Yes, good question/ I would be interested to here if there's any alternative stem/leonlikestrees wrote: ↑Sat Sep 10, 2022 8:01 pmI've got the TCR advanced one with the 1/8th steerer. I really like the integrated look with the spacers, but them stem is pretty heavy (174g).
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
Is that the Black Inc integrated stem/bar combo designed for their Ostro Vam frame? seems to be a great fir for the Giant spacers. Could you post a close photo of the stem/headset spacer area please? Thanks.
That Terracotta colour scheme is very striking - did you happen to get a weight for the frame and fork? Cheers.
Yes, that does look good. What headset cap is he using there - it looks like FSA but I can't quite make it out?
I belive it's a cover from previous generation of tcr that used round spacers. It sais overdrive on it...
Anyhow you can use canyon's top cover but you'll have to shim it in order to preload the bearings properly. Without the shim top cap will just lock the bearing.
Sent from my SM-G970F using Tapatalk
