sram axs 1x oval chainring garbaruk weight
NICE! Where did you pick that ring up? Directly from Garbaruk?
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
P-X Spitfire Ti
Fairlight Strael
Old
good to see you're obviously adhering to Rule #25.
lol
fo sho. here's another example
I just installed the AXS aero direct mount 46T chainring on a Sram Froce AXS Crank on a Trek Speed Concept and the chainring is very loud in lowest 34T and highest gear 10T. Feels like the chain line is all wrong maybe? Anyone else had issues with the noise on the garbaruk chainrings. The solid design of the aero rings seems to be prone to vibration noises maybe? Is it a chainline issue? Chain length issue? The chain seams to be all over the place when in the 10T ring. Hard to explain but it doesn't seem right to me.
I have just got a 54T chainring from Garbaruk and I am actually going through a nightmare with them.
I have received 4 different chainring for warranty and all of them are faulty as they do not fit properly on the Sram AXS red cranks.
It is not possible to screw in enough the 8 screws and as a result it touches the bearings of the BB.
They claim they sold many of these rings without any issues but on my side, out of 4 rings, none of them offer a proper fit.
Did any of you experienced a fitting issue?
Here a video for reference:
and here few pictures:
Thanks
Thanks
I gave up on these and picked up some Stone aero chainrings. Round, not oval but they're less expensive and a better product.
So the bolts are hitting the BB? . Add a spacer so they don't and it will be fine.ThomasLCMT wrote: βWed May 05, 2021 1:22 pmI have just got a 54T chainring from Garbaruk and I am actually going through a nightmare with them.
Thanks
Thanks for the info. Do you have a picture by any chance?Steve Curtis wrote: βWed Aug 11, 2021 3:37 pmI gave up on these and picked up some Stone aero chainrings. Round, not oval but they're less expensive and a better product.
Raymonndo wrote: βWed Aug 11, 2021 8:27 pmThanks for the info. Do you have a picture by any chance?Steve Curtis wrote: βWed Aug 11, 2021 3:37 pmI gave up on these and picked up some Stone aero chainrings. Round, not oval but they're less expensive and a better product.
Cheers Steve, it looks good! I think I will try one. Curious what size front ring you run with what cassette ratio? Noticed your 1X. Course not sure what your local area is like to gauge but just curious .Steve Curtis wrote: βWed Aug 11, 2021 8:55 pmRaymonndo wrote: βWed Aug 11, 2021 8:27 pmThanks for the info. Do you have a picture by any chance?Steve Curtis wrote: βWed Aug 11, 2021 3:37 pmI gave up on these and picked up some Stone aero chainrings. Round, not oval but they're less expensive and a better product.
S3 has a 54 11-28
Black disc 48 10-33 ( to be fitted, just waiting on a red groupset )
Black rim brake. 52 11-32
I live in a rolling part of Ireland. 7-10% climbs are normal but mostly undulating
The 10-33 should be the perfect ratio with a 48t. It's quicker than the 52 - 11 but has better ratio at the other end for climbing .
