Dura-Ace R9200
ricerocket
by ricerocket
BdaGhisallo wrote:
Wed May 18, 2022 9:09 pm
Has anyone seen any news on when the 9200 and 8100 powermeters will be available?
Stages is selling R8100 PMs already, the R9200 listing has been created.
Not sure I'd hold out for the Shimano one TBH.
Matte86
by Matte86
Has anyone tried already the latest YBN chain on 9200? How does it shift?
I’d like to put it a gold one, but I haven’t find any review/experience
Thanks
BdaGhisallo
by BdaGhisallo
ricerocket wrote:
Wed May 18, 2022 9:37 pm
I'm a little bit wary of single sided PM's. I might wait and see how the Shimano PM's turn out.
Vincentsmoox
by Vincentsmoox
Matte86 wrote:Has anyone tried already the latest YBN chain on 9200? How does it shift?
Thanks
I only tried kmc dlc 12sp
Shifting is ok, but oN one (number 4 If im not wrong) cog they not doing well, chain cant go in some teeth
Change back to Shimano.
gSporco
by gSporco
Anyone compare the XTR vs XT chains? Is it really worht the extra money for the XTR 9100 12sp chain?
@gSporco - Instagram
Specialized Aethos
State All Road 6061
Retired Cervelo Aspero
Matte86
by Matte86
Thanks
Thanks!
That’s my worry.. back to boring silver then Image
tmanley
by tmanley
First time DA user question - if I move to a larger rear cassette, say 11-30 to 11-34, any RD adjustments I should double check?
-Thanks, Todd
kode54
by kode54
You may need to have a longer chain and adjust B screw.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
harblhat
by harblhat
tmanley wrote:
Thu May 19, 2022 8:19 pm
The usual things you would check when changing cassette size. B-gap (the manual states gap is different between 30 and 34), chain length (will definitely need longer for a larger cassette), and general shifting alignment and limits after the swap. If you have semi-synchro or synchro enabled, you should update the cassette size in the E-tube app as well.
carborush
by carborush
Just fitted a 34 cassette and a longer chain.
The top pulley wheel teeth are touching the teeth from de 34.
Any advice ?
I'm guessing tensioning the B screw to pull back de derailleur slightly ?
tmanley
by tmanley
Thanks for the replies and assistance - RD fixed and FD too.
ryanw
by ryanw
Screw in b-screw to attain a 6mm gap from pulley to 34 cog
IG: RhinosWorkshop
kode54
by kode54
There’s a RD to cassette guide included. Use that and adjust B screw accordingly.
- Factor LS Disc
overl0ad
by overl0ad
BdaGhisallo wrote:
Thu May 19, 2022 10:38 am
i got some SRM X-Powers, cos i ride SPD on my roadie. got the dual sided. no idea what's going on, but i now have an average of 20/50 split and output 270 90% of the time... SRM can't tell me what's wrong. and i'm getting peeved at it...
kgibbo1868
by kgibbo1868
gSporco wrote:Anyone compare the XTR vs XT chains? Is it really worht the extra money for the XTR 9100 12sp chain?
I have used both, go with the XT, great value, great performance. XTR will save a few grams, but shifting performance is identical in my experience.
2019 Baum Ristretto
Pain is my friend!
