ZTTO 11-36T(235g), 11-34T(228g), 11-32T(216g) 11s cassettes
ive been trying to find a WW cassette on 2 x GRX and bought 2 cassettes from ZTTO
11-36 and 11-34
for some reason while using the ZTTO cassettes the chain always hit the rear derailluer.
i swapped like for like. Bike was using a shimano 11-34 which works fine, then swapped over to ZTTO 11-34 and the change points on the ZTTO in the middle always make the chain hit the below.
anyone know why this occurs?
how far should one adjust the B tension?
If i adjust the B tension screw to stop the above it then slightly touches the di2 cable and makes the shifting crap
11-36 and 11-34
- robbosmans
- Moderator
- Contact:
Show a picture of your derailleur hanger, it looks like you are using a normal hanger as a direct mount
Bought a ZTTO 11-32 cassette in the November sales for A$58 delivered, and finally got a chnace to fit it and ride it for a bit. At the same timne, aslo bought a pair of lightly used SRAM Red versions for A$300 for the pair.
The ZTTO fitted fine, and for the most part worked a treat, but have found that at medium load or higher, in the 15T cog, it will skip a tooth. Need to pull it off an have a closer look, and unless I can work the cause out, it'll end up in the recycling bin.
Meh, had to try
Meh, had to try
If and old chain skips on a new cassette, you have to replace the chain.MichaelB wrote: ↑Tue Apr 13, 2021 11:40 pmThe ZTTO fitted fine, and for the most part worked a treat, but have found that at medium load or higher, in the 15T cog, it will skip a tooth. Need to pull it off an have a closer look, and unless I can work the cause out, it'll end up in the recycling bin.
Marin wrote: ↑Wed Apr 14, 2021 9:26 amNew chain with <100km before cassette fitted.MichaelB wrote: ↑Tue Apr 13, 2021 11:40 pmThe ZTTO fitted fine, and for the most part worked a treat, but have found that at medium load or higher, in the 15T cog, it will skip a tooth. Need to pull it off an have a closer look, and unless I can work the cause out, it'll end up in the recycling bin.
All other cogs fine
I recently got a 11-28 Ztto cassette for my ultegra di2 Tarmac SL7. I have to say it works really fine. Sometimes it does not shift from 14 to 15 but I guess with a slight adjustment it will work. Other than that shifting is not much worse than on my Ultegra cassette.
Next days I will also try to merge the ultegra and Ztto cassette. Lets see.
