Road shadow RDs with GS cage support 36 cog and in some cases even more. The 32t on SS might cause issues, true (that' what I have).
ZTTO 11-36T(235g), 11-34T(228g), 11-32T(216g) 11s cassettes
C36 is specifically asking about the 9150 which only comes in SS (no GS available).Klaster_1 wrote:Road shadow RDs with GS cage support 36 cog and in some cases even more. The 32t on SS might cause issues, true (that' what I have).
I am also curious about an 11-36 working on an SS derailleur. I’m sure it has to do with just being lucky with the particular model of bike it’s on. Shimano is generally conservative so that all bikes work within their guidelines.
2017 Giant TCR Advanced Pro 0 Disc
2003 Cannondale R1000 (CAAD7)
It depends on your bike's hanger length. I had to turn the B-screw most of the way in, but it shifts up to the 36T smoothly with room to spare. I think I'm good up to 38T.
Watch this video on shifting big gears with Shimano DA 9100/9150 derailleurs: https://www.youtube.com/watch?v=rQbhMaveqcw
Cage length for Dura Ace 9150 SS rear derailleur is 72mm long, which is fairly long and only 8mm shorter than SRAM XX long cage rear derailleur. I had SRAM XX on my bike before switching over to DA Di2, and the XX handled the XTR 11-40T cassette just fine.LiquidCooled wrote: ↑Sun Apr 05, 2020 9:30 pmI am also curious about an 11-36 working on an SS derailleur.
Hi there, how about 11-38T or 11-40T road cassette? There are some 18% - 20% hills around where I live I have the Shimano XTR 11-40T cassette, but that thing weighs 329g. Hoping to save a few grams with your alloy version. Thanks.
Thanks for the tip, I had no idea 9150 is SS only.LiquidCooled wrote: ↑Sun Apr 05, 2020 9:30 pmC36 is specifically asking about the 9150 which only comes in SS (no GS available).
Is it possible to use either a Wolf Tooth Goat Link...
https://www.wolftoothcomponents.com/col ... s/goatlink
or
is it possible to use this Leonardi range extension pulley...
https://leonardistore.com/collections/p ... o-11-speed
or
RichardL wrote: ↑Sun Apr 05, 2020 9:46 pmCage length for Dura Ace 9150 SS rear derailleur is 72mm long, which is fairly long and only 8mm shorter than SRAM XX long cage rear derailleur. I had SRAM XX on my bike before switching over to DA Di2, and the XX handled the XTR 11-40T cassette just fine.LiquidCooled wrote: ↑Sun Apr 05, 2020 9:30 pmI am also curious about an 11-36 working on an SS derailleur.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
I ordered a cassette probably 3 weeks ago... I think they just shipped it yesterday? Just a heads up
Did you ask for an explanation?
Then again, I think this would've probably been the time when they lifted the restrictions in China, so they needed to work on the older orders and they're probably just getting caught up now.
I'm planning to make an order and use DHL shipping as I'll need the parts soon
I'm planning to make an order and use DHL shipping as I'll need the parts soon, BUT I noticed on the checkout they'll charge you shipping 3x. Anyone come across this?
Aliexpress as a platform allows sellers to change shipping methods, to change tracking numbers (platform penalize sellers only if they are reaching Max shipping time, but max time is usually set at 2x or 3x time of regualy shipping time)
I am not sure if DHL will be faster, ask seller about this. If you want to change shipping method I suggest you to message seller before doing that and ask him what you want, and how many days he needs to processing order with this shipping method.
After getting reply, before placing order, add again shipping information to comment section of order
I have three of these cassettes now. Two work perfectly but one will not shift correctly, in to or out of the 3 smallest sprocket.
Same bike and same wheels etc and it still won't work regardless of how much I change things.
I've tried it on 6 bikes and it still won't work.
Be careful when you buy one of these and test it thoroughly before leaving feedback.
Aliexpress weren't interested in helping me so I'm stuck with a cassette I can't use
So when you leave the feedback it'll be final with no recourse? I guess riding it a month straight would be recommended before leaving a feedbackSteve Curtis wrote: ↑Tue May 19, 2020 6:21 pmI have three of these cassettes now. Two work perfectly but one will not shift correctly, in to or out of the 3 smallest sprocket.
