Forum rules
TobinHatesYou
by TobinHatesYou on Fri Dec 07, 2018 6:35 am
jfranci3 wrote: ↑Fri Dec 07, 2018 6:03 am
50ml of sealant is 100% reasonable. The real crime was not having a normal tube or 25mm tire like any normal bike would have.
Giving up a 1.2w of resistance per pair on a bike roller vs a latex bike tube is no big deal. Saving ~3w per pair over a GP4k is a big deal.
50mL is completely unnecessary. I use 30mL in 28mm tires measuring >30mm. If I puncture a couple times I top it off with another 10mL. I just pulled the old worn tires off a wheelset I haven't touched since March or April, there was still liquid Orange Seal in there.
pdlpsher1
by pdlpsher1 on Fri Dec 07, 2018 7:14 am
TobinHatesYou wrote: ↑Fri Dec 07, 2018 1:30 am
All my sidewall cuts were well within life expectancy of the tread, making it a non-factor. 200 miles, 500 miles, etc.
It's not just you. I have had a GP4K get cut on the sidewall with less than 100mi on a new tire. But I attribute that to bad luck, not because the sidewalls are fragile. Year-to-date I have logged 12,985mi, all road miles and zero trainer miles, and only had one cut sidwall. And that cut happend on the tandem, on the rear tire, and after we had just crossed a railroad track.
jlok
by jlok on Fri Dec 07, 2018 8:51 am
TobinHatesYou wrote: ↑Thu Dec 06, 2018 2:49 pm
If you notice GP4K sidewalls, although they are black,
the protective rubber coating over the nylon threads is minimal. Maybe that 3x110tpi construction method isn’t the greatest either.
Exactly. It's so thin and it probably contributed a sidewall breakage at the mould boundary on sidewall on my 25c GP4KS2.
bm0p700f
- in the industry
by bm0p700f on Fri Dec 07, 2018 12:18 pm
From experience 30ml is not enough. The good year tyres I tried absorb 35g of sealant. between that ( there was no latex coating the tyre so itust be in the tyre) there was none left to seal punctures. I put 40ml in.
bm0p700f
- in the industry
by bm0p700f on Fri Dec 07, 2018 12:19 pm
dvq
by dvq on Fri Dec 07, 2018 1:20 pm
I'll try a set of gp5000 in 28mm when I can get my hands on them but I'm not holding my breath. For years I believed the internet cult worship of GP4000s and just kept buying them even though 75% of them never made it past 800 mi. Every single one died of a sidewall puncture. On one occasion friend installed a brand new set before a ride and 3 blocks from his house, sidewall puncture. We'll see...
dvq
by dvq on Fri Dec 07, 2018 1:26 pm
bm0p700f wrote: ↑Fri Dec 07, 2018 12:19 pm
I use 50ml personally just because I'd like to be able to get a weeper of a puncture and still not refill for a bit. I've also tried 10 different tubeless road tires now and haven't seen any of them soak up sealant like that. Is that just the Goodyear's?
TobinHatesYou
by TobinHatesYou on Fri Dec 07, 2018 2:29 pm
When dvq and I talked to the Goodyear rep at Sea Otter, he boasted that the tires on display were holding air without any sealant. I can’t imagine an airtight system soaking up sealant like that. Where is the sealant going?
bm0p700f
- in the industry
by bm0p700f on Sun Dec 09, 2018 11:02 pm
Effetto Mariposa Caffe latex. I have never seen a tyre soak sealant like that either.
The good year rep is telling me that maybe the bulging/blistering is the result of the sealant used.
That's another new one on me. Tyres not working with certain brands of sealant. They are recommending stans with these tyres. There test is to run the tyre for 500km on a drum. My reply. I do that in a week, well not this week and it takes two weeks on commuting to rack up 500km. Anyway I'll give the Goodyear another shot with different sealant and see. I'll probably run stans front and an artificial latex sealant rear. Got a bottle of orange to use up. I weight tyres after two weeks and see.
bm0p700f
- in the industry
by bm0p700f on Sun Dec 09, 2018 11:27 pm
Probably on non tubeless MTB tyres. Tubeless tyres should be able to cope with sealant. There were no instructions with the tyre to say only use brand X sealant.
pdlpsher1
by pdlpsher1 on Mon Dec 10, 2018 7:35 am
Another member reported that the GP5K 28mm is just a tad wider than the GP4K 25mm. So I would go with the GP5K 25mm if I were you. I have a pair of the 28mm on order for my Boras and I intend to use them over winter where aerodynamics is not a priority.
