Thanks buddy. Is this one the right one?
https://www.bbinfinite.com/products/bb3 ... 9864652739
Not sure but sure sounds dope
Yup, that is the right one for the 24mm spindle Shimano cranksetsiankovski wrote: ↑Sun Jul 16, 2023 6:10 pmThanks buddy. Is this one the right one?
Glad you're able to solve. Might be because I have v1 expander but pretensioning was the only way to stop it from loosening. I went as far as machining a stem cap to have more threads to tension but it was actually the expander slipping inside (contact points of the V1 expander is literally just the 4 corners).iankovski wrote: ↑Sun Aug 20, 2023 10:48 pmGuys, after reading all the replies in the topic about the headset becoming loose and more than 10 tries I was able to solve the problem. My take is: none of these is related to tensioning or pretensioning the stem bolts but having some clearance on the top cap to further apply 10-12 Nm to press the cap against the stem+fork and create the right pressure on the set to have them firmly.
I also found a video that Look posted last year on YouTube that helps to understand a bit better the process:
Thanks to everyone that helped to solve it.
Me either but somehow it worked. Do you guys tried to tweak or modified the expander adding some tape or any anti-slippery stuff on it?bearapy wrote: ↑Tue Aug 22, 2023 10:45 amGlad you're able to solve. Might be because I have v1 expander but pretensioning was the only way to stop it from loosening. I went as far as machining a stem cap to have more threads to tension but it was actually the expander slipping inside (contact points of the V1 expander is literally just the 4 corners).iankovski wrote: ↑Sun Aug 20, 2023 10:48 pmGuys, after reading all the replies in the topic about the headset becoming loose and more than 10 tries I was able to solve the problem. My take is: none of these is related to tensioning or pretensioning the stem bolts but having some clearance on the top cap to further apply 10-12 Nm to press the cap against the stem+fork and create the right pressure on the set to have them firmly.
Yep, this also impressed me the most. I don't know if they mentioned wrong but in the manual it's also 8Nm.
I've done TransPytennes and there's nothing funky about the off-road sections on it. From my count they probably resume to some 3kms on the entire course, which is nothing compared to the whole journey.Chan73 wrote: ↑Fri Sep 08, 2023 9:33 am
The reason for my question is that I'm taking part in the TransPyrenees Race at the end of September where there are gonna be some funky off-road sections and I'm thinking a GP5000 AS TR 32mm would add some toughness against punctures, as well as comfort over the 1700km.
Don't have the file since the organization only provides it for participants and I'm not going this year, but last year the route was the one I'm pasting bellow. Routes don't vary much from year to year because you make the most iconic Cols, but yes, take a look at this year route and see if the gravel bits are that much longer than usual.
