Raised bar vs spacers
yeah, aesthetic wise, -7 angle stem is the default choice
until it can't be low enough then change to...
-10 degree bring you down by about 6mm
-12 degree bring you down by about 9mm
-17 degree bring you down by about 19mm
select a suitable one, and then add spacer if neccessery. but it'll still be less than 2cm even in case of changing from -7 to -17.
On the upward side, S-works Aerofly (hover version) bring bar up by whopping 2.5cm.
"-7 degree stem along with 6mm spacer" and "-17 degree stem with no spacer and riser bar" will be just at the same height.
while -7 degree stem looks fine on normal bar, IMO Aerofly with raised doesn't look right without the -17 degree stem. so by changing from -7 degree stem to -17 degree stem with the hover bar, you only eliminate 6mm spacer.
I still think it looks pretty cool, and i'd use "-17 degree stem, no spacer with hover bar" rather than "-7 degree stem, 6mm spacer, normal bar" anyway.
Unfortunately it's not an available choice for me as i need lower stack than that.
Aesthetically, quill stems in threaded steerers look better than anything threadless.
IMO a bike looks weird without spacers. I even design my frames to be run with spacers to get the top tube lower.
- wheelsONfire
I had a buddy asking me how i could buy a non race bike, non aero.
But he rides with 30 mm spacers, 100mm -6 stem, on most of his bikes.
Needless to say, but i did find his remarks a bit off.
Bikes:
Open *UP* (2016.04.14)
That wrap job should be a criminal offense. I do know how big of a pain S-Works HD and also Supacaz are to wrap around tight bends though.
I like it. Cool bike.
Euro Fluoro Pro
Europe has already many problems, why blame on us for FLUORO too?
Back to topic, spacers are like a son stepping on your foot's finger, you can't do anything! But rise bar....
Don't get me started on Brexit!! Farage
