Swap Colnago C60 for Sarto, am I mental?
AJS914
by AJS914
I've seen one Sarto in the wild and it was gorgeous.
But it sounds like you are looking for a way to spend money you don't have. Buy the Sarto outright if you can afford it. If not, keep enjoying your C60 that is perfect. Personally, I'd want to ride the Sarto first before selling my C60 in case it didn't work out.
scale29
by scale29
AJS914 wrote:I've seen one Sarto in the wild and it was gorgeous.
Very judgemental, who are you to tell me how much money I may or may not have and how to spend it?
AJS914
by AJS914
Lighten up. It's not meant to be judgemental. You said in your first post that you don't have the money to buy the Sarto unless you sell the Colnago.
scale29
by scale29
Ok, you're right. That was how I phrased it. I can readily afford the Sarto, but see no reason to keep 2 almost identical bikes at the same time so would look to move the C60 on. As it is currently though, I'll probably keep it.
I am keen to join the disc brake movement at some point and until recently the Colnago solution was ugly but notice they now do a flat mount and bolt through option, although the colour options aren't rocking my world.
mrgray
by mrgray
@scale29 did this sarto ever come about? be nice to see it built and know what weight you ended up at.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR :D
dastott
by dastott
You have a bike you love, the C60, with some of the best alloy clinchers, Mavic Exalith. I have these same wheels too, they look good for alloy clinchers and are pretty light. I have carbon tubs and carbon clinchers too and often use the Exalith wheel on the front with a carbon clincher on the back. Both wheels are black so it looks fine IMO.
scale29
by scale29
@mr gray, no not yet. Still seriously thinking about it as I’ve been riding a Di2/hydro bike all winter and convinced this is the way forward for my summer bike too.
They’re expensive and long delivery times, so I’d like to see one in person before committing.
RyanH
by RyanH
A guy I ride with has the matte grey/red dinamica. It looks fine but nothing special. I don't know if seeing one in person will help. Painted frames are hard to judge by looks IMO, it's not like a nude Z Zero or Crumpton where you get a chance to see the carbon layup.
tonytourist
by tonytourist
Ditch the C60 :thumbup:
MyM3Coupe
by MyM3Coupe
Not metal at all. I’d take a Sarto over anything Colnago has made the last 20 years. Sarto “makes” frames tube to tube construction and stuff, whereas Colnago just buys pre-made tubes and glues them together. Hardly worthy of a price tag over $1200. Ernesto has overused his clout and clover.
Seedster
by Seedster
A shop near me carries Sarto. They are some of the most beautiful frames that are truly tailor made in Italy. You tell them how you ride, your weight, desired response and they do the rest. The weight is recorded throughout the manufacturing process from bare tubes to painted frame. My only criticism is with The paint schemes, which are kind of boring. I’d take a Sarto Seta over any Colnago C-Series
audioblazer
by audioblazer
Boring paint scheme ? Not so . If u goggle the images of Sarto bikes 🚲, there are pretty striking
Zakalwe
by Zakalwe
MyM3Coupe wrote:
Sun Apr 15, 2018 4:00 am
What do you think tube to tube construction is, if not just taking tubes and gluing them together?
lone wheeler
by lone wheeler
Maybe but if that's a good example above then Stevie Wonder's done an awful job! Holy Tower spacer batman especially for a made to measure. Keep the C60!
fordred
by fordred
lone wheeler wrote:
Fri May 18, 2018 7:00 am
Right?
That tower of spacers is so ugly, not to mention unsafe. Sure this is a custom frame?
I'm not turned on by the paintwork either.
Colnago for me please. No 4 months lead time and better resale should you decide to change bike in the future.
