Thanks much, I'll see if I can try to find a used or damaged pair.Suby wrote: ↑Sun Nov 18, 2018 9:07 amHey,
Sorry for the delay, but for some reason I cannot reply to PMs; I dont see a button for it (I'm assuming my post count is too low...?).
Modifying the sprint shifters is easy, the hard part is justifying the cost because you'll need to purchase both the Sprint Shifters and Blips, and only use 50% of each, trashing the rest... I found both for fairly cheap on eBay, so in total I spent as much as a new pair of sprint shifters.
It's as simple as cutting, soldering two wires and heat shrinking them. There's no specific +/- wire, so it doesn't matter which two you solder together. Just make sure you solder the right ends together: Sprint Shifter switches to eTap connectors.
201x Specialized Allez Sprint DSW and Gen2
- IrrelevantD
If you haven't already figured it out ('cause nobody's answered your question yet), the shift cables are not full housing. Top of the downtube has stops that are removable, bottom of the downtube has actual stops. I'm assuming they are a PITA if the guide tubes get pulled out, but as I ran mine Di2, I don't know.JonnyBax wrote: ↑Wed Nov 07, 2018 11:40 pmI've got a potentially dumb questions. I know the rear brake runs full cable housing thru the top tube, but do the FD and RD run full cable housings through the downtube as well?
I have had a frame for a while and just got an R8000 groupset delivered. The groupset was the last thing I was waiting for. It's my first build so any tips would be much appreciated!
Thanks for the response! I hadn't exactly figured it out yet, but I left town for Thanksgiving week and figured I'd get back to it when I get home.IrrelevantD wrote: ↑Fri Nov 23, 2018 4:51 pmIf you haven't already figured it out ('cause nobody's answered your question yet), the shift cables are not full housing. Top of the downtube has stops that are removable, bottom of the downtube has actual stops. I'm assuming they are a PITA if the guide tubes get pulled out, but as I ran mine Di2, I don't know.JonnyBax wrote: ↑Wed Nov 07, 2018 11:40 pmI've got a potentially dumb questions. I know the rear brake runs full cable housing thru the top tube, but do the FD and RD run full cable housings through the downtube as well?
Damn, that's a stellar deal.Monkeyfudger wrote: ↑Fri Nov 23, 2018 7:43 pmAnyone in the UK fancy a discounted Sprint?
https://www.hargrovescycles.co.uk/speci ... -bike.html
All the 2018 rim brake Allez Sprints are officially on closeout from Specialized. That is a really good price though! World wide, check with your dealers, the MAP got slashed on those particular bikes.Monkeyfudger wrote: ↑Fri Nov 23, 2018 7:43 pmAnyone in the UK fancy a discounted Sprint?
- Moderator
Wrist angle, comfort and to mimic my tt position easier. Will try more aggressive on the disc allez when I build it.wheelbuilder wrote:Curious as to why you cant your levers so far inboard? Riding style? Comfort?
Using Tapatalk
That road surface looks bloody awful!
It’s nice you’re opening up the hurt with a front light strapped on
- IrrelevantD
Aside from the mad sock game and the laces that apear to change color in the middle... I"m actually super impressed by what apears to be a 12-13year old kid leading out everyone else.
- wheelbuilder
Ah yes. I see what you are doing there......you can rest your forearms on the tops/flares of the bars and keep a comfortable position for your hands on the hoods. Thanks for the explanation...... I also noticed that apparently super young kid, and thought, what kind of a field is this?!!!
- Moderator
IrrelevantD wrote:Aside from the mad sock game and the laces that apear to change color in the middle... I"m actually super impressed by what apears to be a 12-13year old kid leading out everyone else.
Heffron Park Tuesday night handicap. The young bloke is 15/16 from memory and pretty handy on a bike. There's A B1 B C grades and he has recently been bumped from C to B, pretty sure that was just as B1 were coming through B.Monkeyfudger wrote:That road surface looks bloody awful!
It's a goat track with plenty of holes and rough patches but the grass has no lip all the way around so is free real estate haha.
Lights and saddle bag usually stay on if I'm being lazy, sock game is the only game I have and the laces are cut and stitched together to match the club kit.
Using Tapatalk
Heffron is a shithole- jackasses like you love the surface so much that the club refuses to clean it up. Is that the famous cycling photographer Beardy McBeard wheel sucking in the 3rd pic?Nefarious86 wrote: ↑Sun Dec 16, 2018 5:37 amIt's a goat track with plenty of holes and rough patches but the grass has no lip all the way around so is free real estate haha.
- Moderator
That is the Magical Beard on my wheel
Using Tapatalk
