Titanium Spindles for PDM9100 and R8000
- eucalyptus
AFAIK the Ultegra pedals don't use cup and cone bearings. So longevity shouldn't be compromised too much. You still have the 'soft' Ti spindle mating against the steel inner races on the Ultegra pedals. But that's probably OK if the spindle is machined to a good tolerance.
- eucalyptus
Would you mind sharing some more information?
No play in the axle/pedal?
Weight, power output and milage done?
@kppolich,
Does this as you listed...
https://titaniumplanet.com/en/transmiss ... 68813.html
work with PD-M9100?
In the description, it clearly states this....
Description and compatibility:
2 Grade 5 titanium alloy (Ti6Al4V) pedal axles with 2 titanium bearing locking screws,
threaded with Loctite threadlocker
Fits Shimano XTR PD-M980, M985, M990, M995 and XTR PD-M9000, M9020 pedals
Caution, not suitable for PD-M9100 and PD-M9120
Weight of titanium axles: Version -3mm = 44 g, Standard = 47 g, +4mm = 51 g
Weight of 8 custom sealed bearings = 14 g
Total weight reduction of the pedal pair compared to the original cartridges
(steel + ring bearings):
45g (-3mm) 47g (0mm), 49g (+4mm)
Q-factors: Version -3mm = 52 mm, Standard = 55 mm, +4mm = 59 mm
Easy to repack and be careful to reuse the plastic sleeve and the aluminum lock nut
Rider weight limit 120 kg
work with PD-M9100?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
No play in left pedal, slightest starting in right pedal after 5500 miles, 4.8w/kg FTP, 155lbs, 930w for 30 seconds.....eucalyptus wrote: ↑Tue Jun 28, 2022 8:20 pm
Having play after 5500 miles is not flawless. It's 6 months riding or less for many on here.kppolich wrote: ↑Wed Jun 29, 2022 5:21 pmNo play in left pedal, slightest starting in right pedal after 5500 miles, 4.8w/kg FTP, 155lbs, 930w for 30 seconds.....eucalyptus wrote: ↑Tue Jun 28, 2022 8:20 pm
Flawless is DA pedals running year after year with zero maintenance.
I have three years on my DA 9000 pedals with the Titanium Planet spindles. They've been rock solid.
This is completely useless without mileage. For some people three years is 3 000 miles, for others it's 30 000 miles.iamraymond wrote: ↑Thu Jul 06, 2023 10:46 amI have three years on my DA 9000 pedals with the Titanium Planet spindles. They've been rock solid.
Strava says 11,000KMs on the bike. On the spindles, probably around 8000km.
https://r2-bike.com/METI-Titanium-Axle- ... short-3-mm Look at the METI solution
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
- robbosmans
- Moderator
- Contact:
Thats only for xtr pedals and features a totally redesigned bearing system, he replaced the loose bal bearings with cartridge bearings to prevent steel/ti bal contact
