What Pressure (front-rear) - tire - your weight (ready to ride) - bike weight (ready to ride)
Forum rules
Super Six Evo hi mod 16.5 lbs
73 kg
21 mm internal wheels, GP5000 TL tubeless with orange seal 75psi front, 80 psi rear
73 kg
- eucalyptus
21mm internal rims
28mm Pirelli P-zero Race (measure 28mm on rim too)
TPU tupes
Bike 6.6kg + 1.5kg for water
Rider 76kg + 1-2kg clothes, shoes, snacks?
Not very accurate when pumping tires, aiming for around 5 to 5.2 bar (72 Psi). Rear usually slightly higher. So between 72 to 79 Psi.
Realise I could probably go lower, I see others with much lower pressure. But I dont want to.
TPU tupes
Me 75kg including kit, Aethos 6.6kg, Alpinist CLX with 21mm internal width, Turbo Cotton's 26mm and latex tubes
Front 65psi and rear 70psi
Whatever the Silca tyre pressure calculator tells me although it's no good for mud. For muddy rides about 15-20psi.
83kg rider, 7kg bike
25mm IRW, 30mm GP5000STR tubeless
62psi F and 64psi R
If it's wet I drop that down to around 58/60.
62psi F and 64psi R
76kg rider, 8kg bike.
25mm IRW
28mm Corsa Next F 55psi
32mm Power Road R 55psi.
25mm IRW
65kg rider / 7kg bike
30mm Label GP5k hooked tubeless
31mm WAM (width as measured)
55~70psi depending on course.
I daily 58-ish psi FR. To give context, people with bad cages eject bottles at +30mph on these roads I show up with sub 60psi. But I also have roads with extremely smooth, freshly paved tarmac so these I can pump high.
Rider weight: 60-65kg
Bike weight: 6-7.8kg
Rim inner width: 23mm, 25mm
Nominal tire width: 28-30mm
Measured tire width: 30-32mm
Pressures: 50-70psi
General riding: 60f/63r
Pressures: 50-70psi
Ride ready bike with gear (computer, Varia, saddle bag, water + bottles, etc.): 9.8 kg (bike alone 7.3kg)
Rider ready to ride: (helmet, shoes, phone, keys, heart strap, etc.): 75.6kg (gear weight 1.7kg)
Total system weight: 85.4 kg
25 mm ID rims with 700x30 tires, WAM 32.5 mm
PSI F: 56 R: 60
OP's pressures seem ridiculously high to me.
PSI F: 56 R: 60
Rider weight: 190lbs
Bike weight: Aethos 10R size 58, 17.1lbs
Currently running ENVE SES 3.4
Rim inner width: 25mm
Tire width: F&R 30mm Continental GP5000S TR
Pressures: FRONT 49.4 PSI REAR 52.6
Tubeless with Silca sealant
I have a Hunt SUB50 Limitless coming towards the end of April. Will run that with a Vitoria Corsa Pro 30mm as well.
- Contact:
Rider with gear: 95kg
Bike with addons: 10kg
Rims: Fulcrum Racing 6 DB, 20mm inner width
Tires: Vittoria Rubino Pro G 2.0 700x28, measured width 30mm
Tubes: factory tubes (no idea)
75psi front
80psi rear
Anything lower feels squishy, should I go higher?
75psi front
80psi rear
