A little help please
I require to convert Giant SLR One 30mm disc wheelset which is on Liv Langma 2020 Advanced to be compatible with Orro Pyro Disc 2019
If I'm correct this would require 12mm thru axle to 5mm QR conversion kits.
Can someone please confirm if this is correct and parts required to do so.
Thanks
Thru Axle to QR
Forum rules
You should just contact Giant.
Googling suggests your wheelset comes with DT Swiss 360 hubs. Generally speaking DT hubs are easy to convert between TA and QR just by swapping endcaps.
