Hi All,
The freehub is from a Token Resolute 45D wheelset but unfortunately my replacement has been on order with both them and the UK distributor for over 18 months now so I've given up hope on them.
The only place I can find the part "Token" branded is NZ so looking into UK preferably or EU options. It looks fairly standard and closest to a Novatec part. The closest I can find online is this from Raleigh but it's a 10 speed road version whereas I need 11. It bolts from the back so isn't attached directly to the freehub, has the 10 male head prongs and a very basic seal. Image of the Raleigh version here: https://247cycleshop.com/8-/-9-/-10-spe ... aring.html
Help appreciated.
Help me ID this freehub please!
Forum rules
- AscentBikes
- in the industry
- Contact:
Sorry, I can't really help with the freehub type.
However, if your rear derailleur can support it, the Shimano HG700 and HG800 11-speed cassettes are designed to work with a 8/9/10spd freehub body.
This may be a workaround if all else fails.
-QX
-QX
- jekyll man
Looks similar to the entry level bontrager wheels of about 10 years ago
Also might be worth trawling through some of the giant options (joytech??)
Official cafe stop tester
Thanks QX, these are my road rather than gravel wheels but that may be my only option if I can't find a better oneAscentBikes wrote: ↑Fri Feb 03, 2023 4:27 pmSorry, I can't really help with the freehub type.
-QX
Thank you, I'll start trawling the archivesjekyll man wrote: ↑Fri Feb 03, 2023 4:41 pmLooks similar to the entry level bontrager wheels of about 10 years ago
Edco make a locknut that allows you to use their 11 speed cassettes on 10 speed freehubs:
https://www.edco-wheels.co.uk/product/red-locknut/
