Thanks, I'm mostly a granfondo rider and I live in the alps with good surface so I'll give a shot to Michelin.
New Michelin Power Cup Tubeless: GP5K S TR competitor
Forum rules
How many milliliters of sealant do you recommend for 25 millimeters tire on 21 ID rim?
Between 30-45mL of Orange Seal. 60mL+ if using something silly like Muc-Off.lukaszzsch wrote: ↑Fri Jun 16, 2023 11:09 pmHow many milliliters of sealant do you recommend for 25 millimeters tire on 21 ID rim?
I’ve got stans no tubes if it really matters.TobinHatesYou wrote:Between 30-45mL of Orange Seal. 60mL+ if using something silly like Muc-Off.lukaszzsch wrote: ↑Fri Jun 16, 2023 11:09 pmHow many milliliters of sealant do you recommend for 25 millimeters tire on 21 ID rim?
Wanted to buy orange seal but I’m afraid of discoloration on sidewalls.
lukaszzsch wrote: ↑Sat Jun 17, 2023 6:11 amI’ve got stans no tubes if it really matters.TobinHatesYou wrote:Between 30-45mL of Orange Seal. 60mL+ if using something silly like Muc-Off.lukaszzsch wrote: ↑Fri Jun 16, 2023 11:09 pmHow many milliliters of sealant do you recommend for 25 millimeters tire on 21 ID rim?
Orange Seal won’t stain a Power Cup sidewall. It’s a vulcanized tire with a 1mm thick casing. Stan’s doesn’t really work at road pressures.
Thank you for recommendation, I’m just ordering orange seal!
The more I ride this tire, the more I like it. Fast as a GP5k, supple similar to Vittoria, easy to mount with a floor pump, hold pressure well, and doesn't get cut up like GP5k. I see no downsides to this tire so far, especially as a daily tire. I hope they expand the line to additional sizes and add a tan 30mm option.
Did anyone try them on hookless rims (Enve 2.3)?
Colnago C68- Enve SES 4.5
S-Works Aethos - Enve SES 2.3
Open MIN.D - Enve SES AR 4.5
Mosaic GT2-45 - Enve SES AR 3.4
Open WI.DE - no money for Enve
6.7s. which are hookless.. no issues so far
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Thanks!
will them then try on the 2.3 and later als the Corsa Pro on the same rim to compare
Hi guys,
My Michelins 25 finally arrived. Mounted them without problems on my Bontrager xxx4 rims, they sealed without sealant. After adding 40 mls of orange seal they hold pressure as good as my tubolitos(nice behavior comparing to 5000s tr that had to be pumped every ride as my tubular wheel set)
Road feeling is grate, as supple as veloflex pro tour tubulars.
But the question is…what pressure should I chose regarding they real width at 21 ID rim?
Tires are 25 mm, measured with is 29,3 mm and so far I keep riding with same pressure as for 28 mm conti. Is my understanding correct that real width is more important than width marked at tire itself?
lukaszzsch wrote: ↑Sun Jun 25, 2023 7:17 am
Inflate them according to WAM.
My 28c power cup clinchers finally arrived. Paired with ride Now tpu tubes allowed me to get the weight of my addict rc to 7.2kg in size 58.
They measure 30,5mm on 21 internal rim. Tread is 25mm.
Was torned between black and yellow sidewalls. But those look preety good. Will test tide then tommorow.
Scott addict rc
Specialized Diverge e5 comp 2019
What is Wam? Wide as marked?TobinHatesYou wrote:lukaszzsch wrote: ↑Sun Jun 25, 2023 7:17 am
Enviado desde mi POCO F2 Pro mediante Tapatalk
