The wheelbuilding thread
Forum rules
F45
by F45
I built some DT xc rims and left the washers out. Let's see if I can explode them.
WILLIAMDENYS
by WILLIAMDENYS
someone would know how much the standard aero spokes on my vision tc24 wheelset would weigh? want to make my wheels some bit lighter with sapim cx rays but dont know how much i will save
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
bm0p700f
by bm0p700f
Not alot and not enough to make it worth itm also if CX rays are lighter they are also less stiff which may lead to brake rub problems.
WILLIAMDENYS
by WILLIAMDENYS
bm0p700f wrote:Not alot and not enough to make it worth itm also if CX rays are lighter they are also less stiff which may lead to brake rub problems.
Yeahhh so not worth the money? And some other spokes? Someone had somen better light stiffer spokes?
Verzonden vanaf mijn iPhone met Tapatalk
vejnemojnen
by vejnemojnen
WILLIAMDENYS wrote:
Wed Nov 21, 2018 12:59 pm
Sapim CX SPRINT. Marginally heavier, bit thicker, much stiffer.. :)
Marin
by Marin
In basically all spokes, stiffness is proportional to weight.
There are no spokes that are lighter AND stiffer - only if you change material, e.g. from steel to carbon fiber, which means new wheels and other issues.
Slammed
by Slammed
Finally recieved my parts after a long wait and got a chance to lace everything up this evening. The front wheel is 606g and the rear 792g. I won't know until I start to tension them, but it looks like all of my spoke lengths are more or less correct.
F45
by F45
What model rims are those?
Slammed
by Slammed
F45 wrote:
Thu Nov 22, 2018 2:42 pm
Kinlin xr19w
AC0
by AC0
Anyone with experiance using Sapim Nipple Freeze? Is it similar to DT Spoke Freeze? Does it have low enough viscosity to be added after the build and does it work when the spoke threads/nipple have been oiled?
Thanks
AC
bm0p700f
by bm0p700f
You use nipple freeze on dry threads only and you apply before lacing. It's too late afterwards.
The answer to your questions should be obvious why oil then use spoke prep. The spoke prep is the lubricant and the thread locker and the corrosion inhibitor. No spoke prep can be added after the build.
F45
by F45
I've been loving ARP torque grease as a spoke prep. it lubricates then dries (takes about a week) so the nipple is slightly harder to turn, but is still lubed years later if that makes sense. I use a 10ml syringe with a 12ga catheter tube and put a little squirt inside the nipple so there's no mess.
Calnago
In Memoriam
by Calnago
@ACO: DT Spoke Freeze is applied after the build, to the spoke and nipple joint and yes, I think you can apply it even if the spoke has been oiled. But double check on that. I don’t know about the Sapim product.
I use Wheelsmith Spokeprep before the build. I just pour a very small “pool” onto a small size piece of glossy photopaper then lightly “roll” the threads of the spokes into it to get just a light (not thick) coating. Provides for smooth threading while building then will set up and prevent the spoke from loosening but not so much that it’s difficult to adjust if you need to later.
bm0p700f
by bm0p700f
I have always applied the Sapim product to the spoke threads. Just a little bit. It quite viscous.
AC0
by AC0
Sounds like the DT Spoke Freeze is quite different from Sapim Nipple Freeze.
From the DT product instructions:
Apply one drop of DT spoke freeze to each nipple-spoke joint (see picture):
on a degrease spoke thread: nipple is firmly fixed – no loosening
on an oiled spoke thread: nipple is fixed – but still can be turned forcefully with a nipple wrench for retruing
It has low viscosity so it is wicked into the threads post build.
In a long ago post, Ric Hjertberg suggested using loctite 220 (not 222) for it's wicking properties.
https://www.wheelfanatyk.com/blog/three ... ding-tips/
AC
