alcatraz wrote: ↑Wed Feb 10, 2021 2:32 amI see what you mean. That's very interesting.
You can't lace the wheel even 2x if you do all the heads on one side as the first cross comes too close to the hub. So that can't be right.
I think you are right that it "looks like" a design flaw at first glance but I'd just lace them conventionally anyway. That's what's intended, even by Tune themselves.
Here's a crazy idea. If you do notice stress at the J-bend there is also the option of countersinking the holes yourself. I wouldn't do it before testing two different brands of spokes there first though. They do have that channel on the inside to help with the head seating, which leads me to believe they know the problem very well. Also, steel spokes are pretty flexible.
Thank you - this explains why all guides advocate alternating head in/out, and tune forbids radial anyway, so 2X it is..
And the hi res images you attached do illustrate well what I've encountered.
Doing further research suggests this is bevelling - not intended as countersinking for the heads - to accomdate the J bend, and guides suggest to always lace that way if bevelling is only on one side.
Given that's not an option I think I will have to alternate anyway - I've had another go at inserting spokes and it is possible both ways but v tight. I'll try some old other sopkes too first.
Failing that I'll get out my countersunk drill bit and pray! Maybe..
