60 ish wheels?
- Cycloholic
Any reccomendation for 60 ish (or even 80 if is something special) wheels? Tubeless, disc and with no loud logos!
Bora WTO 60.Cycloholic wrote: ↑Mon Aug 08, 2022 7:02 pmAny reccomendation for 60 ish (or even 80 if is something special) wheels? Tubeless, disc and with no loud logos!
Next question please.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
Narrow wheels (for 23c tire):
Bora WTO 60: 26.5mm wide <- WTO stand for Wide Tire Optimized. But ironicly, this rim is narrow.
Winspace Hyper D65: 26.5mm wide
Medium-width wheels (for 25-28mm tires):
Winspace Hyper D67: 28mm wide
Shimano Dura-ace C60: 28mm wide
Wide Wheels (for 28mm and wider tires):
Light-Bicycle WR65: 32mm wide
Ascent Polaris 69: 34mm wide
Hunt Limitless 60: 35mm wide
Edit: white out the incorrect part.
Rapide is 51mm deep on the front. But the rear is indeed, over 60mm deep.
WTO stands for "wind tunnel optimized"Hexsense wrote: ↑Mon Aug 08, 2022 10:59 pmNarrow wheels (for 23c tire):
Oops. I misremembered. Thanks.
So that explain why it's not so friendly with wider tires.
Narrower tire+ narrower rim = most aero in wind tunnel.
It just happen that most average people no longer use narrow tires.
So, with wider tires, it need wider rim to maintain the aero performance.
yeah, Campy is definitely conservative on width compared to Zipp/Enve/HED/etc when aiming for 25mm with max of 28mm for best aero performance. Planned tire size and importance of aero certainly should be taken into account for wheel choice.Hexsense wrote: ↑Mon Aug 08, 2022 11:11 pmOops. I misremembered. Thanks.
- Cycloholic
oh right, thats an old favorite! Are they coming with XDR also?rollinslow wrote: ↑Mon Aug 08, 2022 10:27 pmBora WTO 60.Cycloholic wrote: ↑Mon Aug 08, 2022 7:02 pmAny reccomendation for 60 ish (or even 80 if is something special) wheels? Tubeless, disc and with no loud logos!
Yeah, you order them with an XDR freehub body or swap it yourself easily.Cycloholic wrote: ↑Tue Aug 09, 2022 5:30 pmoh right, thats an old favorite! Are they coming with XDR also?rollinslow wrote: ↑Mon Aug 08, 2022 10:27 pmBora WTO 60.Cycloholic wrote: ↑Mon Aug 08, 2022 7:02 pmAny reccomendation for 60 ish (or even 80 if is something special) wheels? Tubeless, disc and with no loud logos!
