superlight allroad carbon rim
What's the difference, for instance, to Lightbicycle AR56? (56x30mm, 23mm inner)
I'm also pretty interested in those hubs. What's the scoop? Any interest in selling them separately?
FWIW, I'd be interested in 12x142 with both an XD and XDR body. I'm also wondering whether a 110x15 front hub will be available.
Thanks!
If you plan on producing a rim-brake version, I'd be happy to test. Road, poor road (chip seal, potholes), light gravel; 88kg rider.kiritozhang wrote: ↑Mon Nov 02, 2020 3:57 pmDue to the Covid-19 epidemic, we were unable to go to Roubaix or Flanders for testing. So we are now calling for beta test riders.
We want to design a pair of wheels: it can conquer all roads, whether it's asphalt, cobblestone or gravel. It can be fitted with wide tires and is lightweight enough when climbing hills.
- kiritozhang
- Contact:
I think AR56 is not suitable to be called all road rim. The height of 56mm is not suitable for Gravel/endurance/climb products. When encountering crosswinds, I would never like a pair of 56mm wheels.
AR56 is suitable for higher speed riding. I think it is just a wide rim.
Riding all kinds of terrain on my Open U.P. in Iceland; tarmac, pavement, gravel, single-track, cx, snow, ice - you name it. Would be happy to test these out in some extreme conditions. Would also be nice to have a comparison to the Roval CL50 "road" wheelset and Stan's Grail CB7 more gravel-oriented wheelset I use on that bike.
- kiritozhang
- Contact:
It is compatible with 25mm tires, but I recommend using 28-30mm tires.wheelsONfire wrote: ↑Mon Nov 02, 2020 7:48 pmSame question here!
Also, what do you (OP) consider low pressure?
When the inner width increases, we will reduce the tire pressure a little when the same tire is installed.
For clincher, a higher tire pressure will result in a tighter combination of the tire and rim.
So when using 25mm tires on this rim, I recommend keeping the tire pressure around 90-100psi. (Depending on weight)
Compatible with 25mm tires just to give riders more choices.
I am wondering about that OEM version of the Carbon-Ti SP X-Hub. It's 30g heavier than the open market version, which is 273g. Also, this version is lacking the bearing preload adjustment, no? Do you have more details on this hub?
Would love to test these and compare them to my Kinlin aluminium rims and Farsport carbon wheels on road and gravel!
Those are not Carbon Ti's. Those are their own produced hubs based on DT's.edchristoph wrote: ↑Tue Nov 03, 2020 8:39 amI am wondering about that OEM version of the Carbon-Ti SP X-Hub. It's 30g heavier than the open market version, which is 273g. Also, this version is lacking the bearing preload adjustment, no? Do you have more details on this hub?
- kiritozhang
- Contact:
Yes, we use axles of the same diameter and thickness.Bearings of the same brand and size.damond wrote: ↑Tue Nov 03, 2020 11:43 amThose are not Carbon Ti's. Those are their own produced hubs based on DT's.edchristoph wrote: ↑Tue Nov 03, 2020 8:39 amI am wondering about that OEM version of the Carbon-Ti SP X-Hub. It's 30g heavier than the open market version, which is 273g. Also, this version is lacking the bearing preload adjustment, no? Do you have more details on this hub?
The same number of holes 24/24.
But we increased the flange distance on the right a little bit.Optimized the lateral stiffness of the rear wheel
- kiritozhang
- Contact:
LB sells rim separately. And we will sell the entire wheelset. Independently design the hub. In order to make the wheelset more in line with our goals.
Proper collocation can produce better performance. This is why many brands do not sell rim separately.
